Thumbnail views
Thumbnail views
2002-09-16 by Cleavis
I know there are a number of thumbnail viewer programs out there.
I've downloaded breeze browser for evaluation and it's fine but
doens't view PSD files which is my habit.
Same appears to be true of ThumbsPlus.
Did I miss something?
I could see saving files as Tiff's without compression - don't know
the consequences or difference from saving as PSD other than a viewer
program could generate a preview.
Cleavis
Re: [Digital BW] Thumbnail views
2002-09-16 by Richard Sintchak
Sunday, September 15, 2002, 11:01:43 PM, Cleavis wrote:
C> I know there are a number of thumbnail viewer programs out there.
C> I've downloaded breeze browser for evaluation and it's fine but
C> doens't view PSD files which is my habit.
C> Same appears to be true of ThumbsPlus.
C> Did I miss something?
C> I could see saving files as Tiff's without compression - don't know
C> the consequences or difference from saving as PSD other than a viewer
C> program could generate a preview.
C> Thanks,
C> Cleavis
A little while ago I looked for a thumbnail viewer that could preview
PSD files too.  ACDSee can preview *some* PSD files but for some
reason not all.  Not sure the why and the how.  The new version of PS,
7.01 has a browser feature that works pretty well.
Best regards,
 Richard
mailto:richard@...
2002-09-16 by Editor P.O.V. Image Service
My experience with ACDSee is the same..
Keith
RE: [Digital BW] Thumbnail views
2002-09-16 by Gus J Grubba
ThumbsPlus has no problems with PSDs as long as you have the "Always
Maximize Compatibility for Photoshop (PSD) Files" option selected in
Edit/Preferences/File Handling. PSD files went through some major
changes after Version 2.5 (starting with Version 3.0). Most third party
programs will only read version 2.5 files. When you have the above
option enabled, Photoshop saves the image in both formats within the
file. That way other programs that normally do not read layered images
(what makes V3+ different), can open it. The disadvantage of doing this
is that your image file will be bigger than otherwise.
If you do not have layers defined, it is better to save these files as
TIFF as just about anything out there can read them while only a few
programs fully support PSD files. It is only advantageous to save an
image as a PSD when working with layers. Non compressed TIFF files are a
global standard. Everything worth anything will read it. The only
problem is when compression is used. There are many different ways to
compress a TIFF file and not all programs support all these different
formats. Of all, LZW is the most common compression method for TIFF
files. Even though it is lossless, it is usually of no use for
photography unless you have very large areas of all blacks or whites.
Compressing a "normal" photograph will result in a larger file than not
compressing it at all.
The advantage of using a program such as ThumbsPlus over Photoshop's (or
even Windows') "browser" is that thumbnails are created once, in one
place (a database). Programs that only create thumbnails on the fly are
useless for large image files while others that create "cache files" all
over the place create a nuisance as you end up with your hard disk full
of spurious files taking a considerable amount of space.
g
Sent: Sunday, September 15, 2002 11:02 PM
Subject: [Digital BW] Thumbnail views
Cleavis
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
- As the topic of a thread changes remember to change the subject
header.
- Good manners are required at all time. No personal attacks or
"flames."
resources on the homepage.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
2002-09-16 by david_bookbinder@sprynet.com
If you want to save as PSD, you might have to check the box in
Preferences that embeds a flattened version of the file, for
"compatibility." This will increase the size of the file but
should make it possible for most programs that say they handle
PSD files to do so.
- David
= = = Original message = = =
know
a viewer
Cleavis
Polls and other resources as they are often being updated. The
page is at:
wish to unsubscribe, please edit your Membership preferences
by visiting this same page.
to keep them short.
header.
or "flames."
the various resources on the homepage.
___________________________________________________________
Sent by ePrompter, the premier email notification software.
Free download at http://www.ePrompter.com.
2002-09-18 by Frank Mares
I just love  PICA view 2.0. It's not a database program but simply a
thumbnail viewer with some nifty little add-ons. It display *.psd files
easily as well as *.nef files from my D1x! Very stable and easy to use.
It makes the Viewer in PS 7 almost archaic. http://www.acdsystems.com
Frank
Francis James Mares Photography
