CIS Carts REinstall
CIS Carts REinstall
2002-09-17 by Mark Romine
To achieve a vacuum with a CIS can this only be done once before the
carts are installed or can a vacuum be achieved at any time after the
carts have had their seal broken by installation? The reason for my
asking I am in the process of installing new carts for my CIS and I am
having trouble getting a vacuum with the new carts already installed.
Mark
Mark Romine
MARK ROMINE PHOTOGRAPHY
227 Fairway Drive
Bloomington, IL 61701
309-662-4258
http://www.markrominephoto.com
Re: CIS Carts REinstall
2002-09-17 by Jeff Randall
Once you install the carts and break the seal over the exit ports,
the game is up.  If you try to pull a vacuum, all you will do is pull
air back through the print head.  I have no idea if this will work,
but you could try to tape over the broken seals, pull a vacuum and
fill the CIS carts, let the inks settle as in the instruction, then
remove the tape and quickly install the carts.  Note:  You should
install an existing set of carts with ink as soon as you remove the
empty CIS carts--you don't want the print head drying out.  Before
you install the full CIS carts, you should make sure you can get a
good nozzle check with the temporary carts.  Since you probably
pulled a lot of air back through the head, you might have to do
several head cleanings and maybe wait overnight.
Good Luck.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., Mark Romine <klick3@g...>
am
installed.
> Thanks,
> Mark
> Mark Romine
> 227 Fairway Drive
> 309-662-4258
2002-09-17 by jim hayes
Well, you could try two different tricks:
1) MIS and maybe we-Ink too sell a plastic plug for the bottom of the
cart chamber. It is a one use thing. It is not the metal Rivet sold by
MIS, not the EZ-plug sold by nomorecarts. This is a big round plastic
plug which MIS should still be selling (let's hope). Go to the MIS
site and look under accesories. You shoe-horn this thing in and it is
supposed to give a fairly good seal, or at least I heard it can-never
tried it myself-look on the we-ink site for the same item and see if
they still give direction for using the plug to do a vacuum refill on
a used cart. Obviously I'm giving all this to you from memory, so
check it out for yourself.
2) MIS has a procedure for getting rid of air or "foamy ink" in their
carts/CFS. The procedure might be listed under CFS FAQ or some such as
"recovery method". But you probably should have some ink in the carts
to start out with. Basically you take a syringe and put a MIS "bottom
fill adapter" on it and suck air/ink out through the bottom of the
cart and return it to the bottle. Repeat many times until the ink
in the drawing syringe has no bubbles left. I don't know whether this
would help you or not- I have used it to clear a tiny bit of air out
of my CFS with good results. It might be adaptable to your problem.
At anyrate, good luck,
Jim H.
am
installed.
> Thanks,
> Mark
> Mark Romine
> 227 Fairway Drive
> 309-662-4258
Sorry, scratch option #1. I don't see that plug listed anywhere on MIS
or other sites anymore. Odd, they used to have it...
Jim H.
--- In DigitalBlackandWhiteThePrint@y..., "jim hayes" <jimhayes@j...>
by
plastic
is
2002-09-17 by Martin Wesley
am
installed.
Mark,
I am not quite sure where you are in the process of installing them
but once the bottom seals are broken you can't get a vacuum on the
cart unless you reseal the bottom openings with something. Try
electrical tape. Also if there is any ink in the cartridges you will
suck it into the vacuum pump, which is not fatal to the pump but very
messy.
If the bottom seals are broken you can also use the original method
of filling the CIS carts by inserting a syringe in the bottom
openings with the tubes already in the ink bottles and pull the ink
into the cart.
Martin Wesley
Thanks Jeff,
Mark
--- In DigitalBlackandWhiteThePrint@y..., "Jeff Randall" <jrandall@c...> wrote:
> the game is up.....
If still interested:
http://www.inksupply.com/index1.cfm?source=html/seal.html
to see pix and instruction for the replacement seal (option#1). Maybe
MIS or someone still has these for sale if you contact them directly.
Jim H.
MIS
> Jim H.
<jimhayes@j...>
> the
sold
> by
> plastic
> is
The replacement seals have an open hole in the middle to fit over the
nipples in the printhead.  They will not hold a vacuum.
Jeff Randall
Maybe
directly.
> Jim H.
<jimhayes@j...>
on
> MIS
> > Jim H.
> <jimhayes@j...>
of
> > the
> sold
> > by
> > plastic
MIS
it
> > is
2002-09-19 by Mark Romine
What about if you pull the carts to clean the heads will this action also break the vacumm?
I have an unbelievable clog, worst I have ever seen in four or five years of printing with Epsons, even after soaking the parking pad with cleaner
and letting it stand overnite the same number of nozzels are still clogged this morning. This is an 1160 btw.
The way this whole problem started, I was getting decresing density in midtones almost to the point of getting posterization. I had not printed
much of anything in six to eight weeks, thus I assumed that the heads were experiencing some build up. So I thought the heads needed cleaning,
pull the CIS carts and flushed each port with windex and a siringe. This resulted in nearly every nozzel being clogged, with cleaning cycles I have
now got about 70 to 75% of nozzels opened. So I thought that I would try cleaning the tubbing and I bought new CIS carts, these are now
installed but no improvements on the clogggs.
Anyone any suggestions?
Mark
2002-09-20 by Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "Mark Romine" <klick3@g...>
Mark:  There is no significant vacuum once the carts are filled with
ink.  The original vacuum is *replaced* with the ink that is sucked
into the cart during the original fill.  The ink then is pulled into
the cart be capilillary action and the tiny vacuum created when the
ink is *pumped* through the printhead.
You major clog could have been caused by pulling air through the head
when you first installed the carts prior to vacuum filling the carts
or drying out of the head during a prolonged installation process.
Jeff Randall
2002-09-20 by jim hayes
No vacuum involved after carts full- but you could get air in the head
and carts. You can remove air from the carts with a syringe and MIS
"bottom fill adapter" using their recovery procedure for a CFS- should
work for a CIS. Even if the ink isn't foamy, it can get out big air
pockets, if by chance it is an issue.
cleaner
printed
If you were getting good nozzle checks, and if the ink was older than
5 or 6 months, and if you had shaken the bottles up just a tad,
then...
You might want to replace the inkset, it sounds like it may have
problems, though I don't know which ink you're using. This condition
was one of the main symptoms of DSS I discovered with the old Piezo
inkset. At best I could only clear about 90% of the problem by
inserting Epson carts. A couple people had more complete sucess by
injecting Fantastik into the heads. In hindsight, I realized that I
should of replaced the ink at that point, as the DSS only came back
within two months.
Use your own discretion of course, inksets can be $$ to replace. And I
would make sure all three conditions above have been met first.
This was the case with my DSS too, as inserting Epson carts
temporarily cleared 90% of problem.
cleaning,
cycles I have
What did you use as ink/fluid to perform the cleaning cycles? I
wouldn't reinstall the CIS with the pig ink. I also would not use
cleaning carts. I would only use Epson carts.
Sounds like air in there- Epson carts/purge patterns could clear. Your
pig ink has to be okay too though. You can run just one color purge
pattern full page or all colors-files on MIS site.
Okay, as suggestions, not as a font of absolute wisdom<g>:
Use Epson carts to flush out heads/with purge patterns. If on the off
chance ink is bad as defined above consider replacing (this would also
mean yet another replacement set of CIS carts). If you stay with the
old CIS carts (punctured seal), this may help slightly... inserting a
syringe with a bottom fill adapter into exit port, drawing out ink,
dumping into bottle, repeating, etc- to remove excess air. Be carefull
not to poke any filter/screen that may be near exit port in CIS cart
when using bottom fill adapter, insert gently.
Jim H.
> Thanks,
> Mark
