Epson SP 2200 metamerism
2002-09-17 by alanjrubin
I have been using the SP 1200 very happily for some time, but have now obtained the 2200 and am in the process of testing and comparison. I use a wintel PC.... First, I am struck by the lack of detailed info [the EPIC facility, which isn't much help also does not run on my PC for some reason]. Therefore, I am grateful for whatever help I can get from this forum or any source for that matter, so please make suggestions. I am also struck by the apparent increase in operating expense compared to my 1200. Further, there is the issue of the obvious metamerism which is the main subject of this note. I have tried a little tweaking since B&W images exhibit a very distinct magenta cast when viewed indoors. Reducing magenta in the "Custom" setup significantly improves the image and apparently reduced the quite green tinge seen under daylight. Please.......any help you all can give....etc. Alan Rubin
