Re: [Digital BW] Re: CIS Reinstall
2002-09-23 by Barbara White
Jeff Randall wrote: > > Barbara: > > Probably not a problem, but you can either suck or blow air from your > syring to remove more of the water. I assume you are talking about > only the hoses. You can't fully clean out the cart and therefore > should not reuse it even if you use the same ink because the sponge > in the cart will hold lots of cleaning water. > > Jeff, Thanks, I'll blow them out. Sometimes the most logical things do not come readily to mind......(and, yes I have new carts) Barbara Barbara White Architectural Photography http://www.barbarawhitephoto.com
