(no subject)
(no subject)
2002-09-27 by rlsopher
Sorry for the cross-post -I put this on archivalcolor by mistake.
My old Random House College Dictionary defines pigment as: A
coloring matter or substance; A dry insoluble substance, usually
pulverized, that when suspended in a liquid vehicle becomes a paint,
ink etc. ...
Well.... There are pigments and there are pigments. Some pigments
are finely particulate minerals that are for practical purposes both
inert and insoluble. Some are particulates derived from an organic
source such as cochineal and may tend to be fugitive. Some azo dyes
are reasonably "permanent" and others are fugitive (check out a
Windsor & Newton or Holbein chart of oil or water colors). Point
being that merely being a pigment is no guarantee of permanence and
being a dye no guarantee that it will not be more or less permanent.
In histochemistry it is common to have a chemical reaction produce
an "insoluble" particulate chromophore at the site of the reaction.
The "pro-dye/pro-pigment", if you will, is a completely soluble
chemical substrate, often uncolored, but becomes a "pigment" under
the proper conditions.
If dye molecules cross link or polymerize when they are "curing"
they can  take on the physical characteristics of a pigment and may,
or may not be more resistant to the effects of UV etc depending on
their chemical structure and they may be insoluble in one vehicle
and very soluble in another.
I think paint and ink making still has a healthy dollop of
witchcraft in it and simplistic claims have to be taken with some
degree of skepticism. Objective testing that describes in physical
terms (such as delta OD) the effect of time, light and temperature
on an ink-paper combination under specified conditions, whether it
be pigment, dye or both  is to my mind the only real arbiter of
permanence. One rub is that there are no generally agreed upon
standards of testing for our needs. This leads to our trying to
interpolate from study to study and try to make sense of what is
somewhat of a muddle.
At this point I would be wary of making any firm statements of
permanence concerning ink jet produced prints beyond a simple
statement that current data suggests that there will be no fading
for at least XXX years under specified conditions. To some extent
that is even true of traditional silver halide prints since their
permanence is largely dependent upon proper archival processing.  I
have a friend with a couple of prints by Atget that are brown and
fading. He has been tempted to try and refix them but then decided
to leave well enough alone. The only claim  I ever made for silver
gelatin prints was they were archivally processed and mounted and
matted on acid free board.
Roger
