Need Printing Help ASAP
2002-10-05 by MARK MAIO
If you can help, please respond to me at: markmaio@...
I am on the digest version of this list and will not get any replies
until this evening if you post your answer to the list.
Problem:
I am using a Mac G3. PS 6, Epson 1280 and Piezography. I printed the 21
step wedge on Super A3 Photo Rag 308 using the Photo Rag 308 setting
with the image centered, and got a good print. I then changed the
setting to Somerset Velvet and then tried to print on the same piece of
paper by changing the position of the image to an offset of 5 inches
from the top and three inches from the left side of the paper. When I
tried to print, it started exporting (printed a thin line at the correct
position), and then the printer (and export bar), stopped and the red
paper light came on. I turned the printer off and then back on, tried it
again with the same result. I turned it off and on again, put my image
position back to centered, tried another print, and it stopped again
after printing a thin line across the top. Can anyone help?
Thank you,
Mark Maio
