Lyson Small Gamut inks w/ which Glossy Paper? Ilford? Canon?
2002-10-08 by rschllr
I was using the Lyson Quad Blacks on an Epson 860 and the Lyson
Monochrome 265g Pro Glossy paper.  Quad blacks were too magenta for
me and I went to the Lyson Small Gamut.   I don't think the Lyson
265g Pro Glossy works as well with the Small Gamut ink.
Can anyone make a recommendation?  Has anyone tried the Canon Pro
Glossy or the Ilford Galerie Glossy?
thanks to all,
Rick
Re: Lyson Small Gamut inks w/ which Glossy Paper? Ilford? Canon?
2002-10-08 by Steve Taylor
--- In DigitalBlackandWhiteThePrint@y..., "rschllr" <rschiller@a...>
> thanks to all,
> Rick
I am using SG inks in an 1160, which I believe is the same as your
printer only bigger. When I print on glossy paper with a colour cast
(i.e. I 'tone' the pic warm or cold), I usually get a nasty blue in
the lighter shadows. I get this even when I tone the pic blue!
This manifests itself much more on glossy papers than the matt /
rough 'art' papers that you can get. (Most of the time it is not
there at all on the matt or art papers.) The nasty blue does not
appear immediately but after a bit of time. I have tried Ilford's
papers and they do this. My best successes have been with Olmec 310
art paper, which I can get cheapish here in the UK. Lyson Soft Art is
nice as well but it is costly. I also use the heavyweight matt papers
and they show the nasty blue effect a bit, but nowhere as much as the
glossy papers. In short, I have found matt/art papers the best so far.
I don't know if this is a problem with the ICC profiles or any colour
management issues - it just seems that the printer / driver is a
little over enthusiastic with the blues at times. I find this whole
matter confusing, so if anyone can shed any light on this I would be
grateful.
I have found that I also get markedly different print colours when
looking at the print under different light - tungsten, flourescent
and daylight. Each is different.
Hope this helps
Steve Taylor
Re: [Digital BW] Lyson Small Gamut inks w/ which Glossy Paper? Ilford? Canon?
2002-10-08 by Kip Babington
I think I get the best glossy results with Small Gamut inks on Ilford
Smooth Gloss.  I tried both the Classic Gloss and Smooth Gloss and decided
the Smooth looked just a bit better.  I'm now working out of a 250 sheet
box of the stuff.
Kip
>thanks to all,
>Rick
2002-10-09 by rschllr
Does the Ilford glossy fade at all.  The Ilford literature says it
will slightly fade after a short amount of time and is to be expected.
Rick
www.rickschiller.com
--- In DigitalBlackandWhiteThePrint@y..., Kip Babington
Ilford
decided
sheet
> box of the stuff.
> Cheers,
> Kip
> >thanks to all,
> >Rick
2002-10-09 by Kip Babington
I have not done any controlled fade testing. I do have a print that's been
sitting in a south facing picture window for about three months, just to
see what heavy sunlight would do to it, and while it doesn't look as dark
as a fresh print would it really isn't that ugly.  None of my regular
photos would ever get that kind of abuse, so I'm just not being concerned
about fading at this point.  Again, not a scientific test, though.
Kip
>Rick
2002-10-09 by colingruk
Rick (and others)
While this does not address your question directly, John Read of
Marrutt,the UK distributor/retailer of Lyson inks, is recommending
custom profiles for Lyson inks.  He has posted links at the bottom of
his main web page www.marrutt.co.uk .
When I return next to the UK I may investigate the quality produced
as I have no personal experience of the results.
Colin
> thanks to all,
> Rick
