Creating curve adjustments for neutral grays on an Epson 2200
2002-10-10 by David Wroblewski
For newbies like myself, who are struggling to tame B/W color casts on
their 2200 by using Photoshop curve adjustment layers, I'd like to suggest
a trick that has made a world of difference for me, and which I've not seen
mentioned before. (And for you experts, if you see a problem in this
process, please correct me before I spread a bad idea.)
(1) Find or generate a simple grayscale step wedge that you like, oriented
horizontally, so it prints out about 1 inch high and 5-6 inches wide. You
are going to print this many times on the same sheet of paper, so to be most
useful it should be less than an inch high when printed.
(2) Use Print Options to set the image's vertical position on the page 0.5
inches from the top (uncheck the "Center Image" check box.) Print the step
wedge without any color adjustment, using whatever printing method you
wish to calibrate (I'm using the Schofield method as posted on The
Luminous Landscape site, which gives me okay results, but a magenta cast at
20% and below.) This is your baseline. Write "baseline" next to the step
wedge when it comes off the printer.
(4) Create a new curves adjustment layer. Make the smallest change you
possibly can, such as (say) adjusting ONLY the green curve at the position
corresponding to the 20% step so it outputs 1 unit more green. Name this
layer "Curves 1". Lock it. You will never change it again.
(5) Select File>Print Options. Increment the vertical position of the step
wedge by 1 inch. Put the same sheet of paper into the printer in the same
orientation, and print. When it comes out, write the name of the new layer
next to the new step wedge, which will now appear just below the last wedge
you printed.
(6) Compare the results from (5) to your baseline and any other step wedges
printed so far. If you are like me, you've fixed some problems and created
some others.
(7) Duplicate the curve adjustment layer from the last step, and increment
the number in its label, e.g. Curves 2. DO NOT change the last adjustment
layer--it is now part of your "trail." In the layers palette, disable the
old curve, enable the new one, and edit the new layer's curve with another
small change. Lock the new layer and go back to (5), making sure that only
the background and the new curve are enabled in the layers palette.
After a while you'll have 9 or 10 step wedges all lined up on a single
page, which makes it quite a bit easier than any other method I've used
(including Gray Balancer) to hunt down color casts. For example, it is
simple to compare how all the variations you've tried react under
different lighting conditions, since they are all on one piece of paper.
You learn just how distantly even miniscule curve adjustments propagate
through the step wedge, etc. Each iteration is relatively quick. And if you
overshoot your corrections, it is easy to go back to the adjustment layer
that produced the best results so far and start over from there.
One other note: I also print out a second baseline step wedge and
carefully trim it so I can hold it directly against any of the step wedges
on the page to see the difference side-by-side. This has significantly
improved my ability to tell if I'm making a global improvement at each
step or whether I am slowly color-shifting my way into, for example, a
uniformly pea-green tonal scale.
I fully intend to buy/build custom profiles, use ImagePrint, wait for
Epson to improve their drivers, or some combination of these
things... eventually. But as a newbie to color wrestling, I feel
I am learning something by doing it the crude, manual way before I buy a
canned solution. I'm definitely gaining an appreciation for the complexity
of the process, in any event. I don't have a curve I am satisfied with
yet, but I'm getting close, and anyway I'm not expecting this process to
yield perfectly neutral output, just an inexpensive & relatively quick
improvement over what I get with Schofield's method.
The only question I have is, can it do any harm to run the paper through
the printer with ink already on it from the prior trials? Will that gunk
anything up if I'm always printing on a clean part of the paper?
David Wroblewski
