[Digital BW] Re: Hmm, More To The Story Than Cone Knows (?) [was] From Piezography3000 .....
2002-10-12 by Paul Roark
Shilesh,
I'm glad someone finally did the "clear base in the black cart"
experiment -- which I've been "going to do someday" for a long time.  Thanks
for the post.
>I loaded MIS clear base in the black ink position.  The color
>cartridge was Epson OEM dyes.  I printed 1-inch square pure black, ...
>1280, ... gamma 2.2, PhotoShop 5.5.  PCM unchecked, using three media
>different settings....
>... After the previous black ink was
>sufficiently purged, the 1-inch pure black squares printed white (!)...
This is what I think is the ideal situation.  To get the deepest black, the
paper ought to be loaded with as much ink as it can hold, and all that ink
should be black ink.  Otherwise, the black ink is being diluted with lower
density ink.
>... So, clearly the post by Cone is not the full story.
I don't understand how he could let a post out that would undercut his
credibility more.  I hope that the settings or whatever produced the results
in his post are explained.
>The Epson driver did not appear to use yellow ink in the
>100% square; in all of the media settings I tried
>(PQIJ, MPHW, and IJBL Film).
>When I used Piezography in these experiments, I more-or-less
>duplicated what was posted by Cone.
That must mean the driver is incapable of pumping out enough black ink to
get the paper up to what it can hold -- or the thing is just purely written.
That result might explain why the Piezo driver produces a weak black
compared to the Epson driver -- at least on the printers I use (1160 &
3000).
>... I doubt the fade seen in PT-K ink
>has much to do with the so-called "workflows".
A good RIP can restrict the black to the darker tones more than the Epson
driver can.  However, this is a 2 edged sword.  The fading/warming PT-K
problem will be more hidden in some images, but the RIP image may also be
more susceptible to a posterization in the deep shadow tones.
http://www.PaulRoark.com
2002-10-12 by Jeff Randall
Shelish's experiment confirms Tyler Boley's statement that "The Epson
RGB driver does not allow any CMY under 100%K."
IMO, Jon's web page comparison between Piezo and Epson/Woolf was more
marketing than science.  What he appears to be trying to show is that
Piezo uses less black and therefore the PiezoTone black should fade
less if using Piezo driver rather than the Epson driver where black
ink is turned on much earlier (simple math -- less fade-prone ink
less fade).
The posted step-wedge printed without black ink using Epson/Woolf
appears to show inking in the 100% patch.  Maybe Jon did not clear
the black head of residual ink (as Shelish did).  Jon also made
statements about where various densities of ink were layed down using
the Epson/Woolf workflow that I could not independantly confirm based
on the posted images.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "Paul Roark"
<paul.roark@v...> wrote:
> Shilesh,
time.  Thanks
> for the post.
black, ...
media
black, the
that ink
with lower
> density ink.
his
the results
ink to
written.
(1160 &
> 3000).
Epson
PT-K
also be
> Paul
2002-10-13 by Shilesh Jani
Hey Paul,
I had no intention of doing the experiment myself, but the original
post peeked my curiosity. The experiment, quick as it was made me
late for my date :-(
One thing I want to clarify: I have nothing against (or for)
Piezography or the PT inks.  I don't use the system because I had
previously developed a system that works very well for me.  The FS
inks I use also allow me to produce experimental mixes of my tonal
prefernce without the burden of the costs associated with PT inks.
Tonal response similar to PT-Selenium is about as easy as things can
get, just add magenta to dark FS in the amount you prefer, use FS and
FSN in the right proportion for the medium ink, and FSN for light
ink, and viola you have a seriously beautiful inset, one that shows
great chromatic complexity even on warmer papers like Satine Soft
White.  Really nothing to it.
Reading the original post, it just did not make sense to me that
fading of the black ink could be blamed on the underlying (or
overlapping) lighter ink.  If the black did not fade organically, the
underlying ink is irrelevant, unless it also fades.  But, I believe
your own experiments have actually shown that the color position PT
inks are some of the most fade resistant inks around.  And I belive I
had read a post somewhere (Antonis Rico?) that Piezography (?) prints
on PR made with PT-S inks showed the fading. Hence, my first reaction
was "oom-gala-gala", i.e. BS.
Regards.
Shilesh
> Shilesh,
time.  Thanks
> for the post.
black, ...
media
black, the
that ink
with lower
> density ink.
his
the results
ink to
written.
(1160 &
> 3000).
Epson
PT-K
also be
> Paul
