Preval spray system for coatings
2002-10-16 by Paul Roark
Has anyone ever used or heard about the "Preval" sprayer?
Although I'm fairly convinced the wire-wound ("Mayer") rod is the best way
to get a near perfect first coat or any water-based coat, I don't have any
interest is cleaning the rod with solvents.  So, since it appears that at
least one solvent-based final coat may be needed to protect the water-based
(and ammonia/Windex sensitive and relatively tacky -- as in touch sensitive)
acrylic, I have been looking at sprays.  If there were an ideal aerosol
spray, I might just stop there.  However, those may not be ideal.  (More on
that as I am able to get information from the sellers.)  So, how to spray
whatever looks to be the best solvent-based solution is of interest.
A Golden tech rep recommended the Preval spray system.  Check out
http://www.prevalspraygun.com/  This looks like a really flexible system
that would be easy to clean.
http://www.PaulRoark.com
