RE: [Digital BW] Re: Calibration, softproof and convert to profile equivalence?
2002-10-21 by Jonah, Jim
Once you "convert to a profile" what you see on screen will not be what
will print. Instead you'll show some colors exaggerated (to make up for
the weakness of those colors in the printer/paper/ink combination).
Unless you get lucky, or your images really don't push up against the
edge of the printable gamut, the ability to have a "single" file that
needs no editing before being printed on  different papers doesn't
really exist.
Working in a color space such as Adobe98 and selecting the profile for
your paper when printing is about as close as you'll get.
By using the soft proof features of PS you can add additional layers
that are specific for certain papers that help counteract the
deficiencies of that paper. i.e. if the Mat paper looses some
saturation, create a saturation layer, give it a name that indicates is
only for printing on Mat paper, and turn it on right before you hit
print - leaving it off for normal viewing/editing/tweaking of the image.
The "convert to a profile" tends to be pretty destructive and really
isn't necessary (unless sending an image to a service bureau that's
requested you do this). Instead, learning how to manipulate the advanced
sections of the print w/preview dialogue boxes will achieve the same
thing without risking accidentally saving your image after you've
converted it, and without having to manage several copies of the files -
one for each paper.
The old motto "K.I.S.S." works well here...
Jim
	Sent: Monday, October 21, 2002 2:34 PM
	Subject: [Digital BW] Re: Calibration, softproof and convert to
	Seems to me you have grasped the whole thing quite well
actually. All
	of your conclusions are correct. The only thing I can't verify
from
	direct experience is the "convert to profile" aproach. It makes
	perfect sense, and is definitely worth trying. The only reason I
	hesitate to say it's a go is because I think I saw a post from
Jon
	Cone that they couldn't verify the aproach there. I'd have tried
it
	myself, but I only use one paper here. It would be worth
remaining in
	16 bit if possible when you do your conversion.
	Good work.
	Tyler
	--- In DigitalBlackandWhiteThePrint@y..., Kevin Gulstene
<kevin@d...>
	wrote:
	> I have used Tyler Boley's write-up of 'matching your monitor's
view to
	> your print' for some time now with good success. Thank you
Tyler.  I am
	> starting to experiment with different papers and, unless I
have
	> misunderstood something, this requires re-editing the image a
little
	> for each paper.  I have created a number of 'profiles', one
for each
	> paper I use.  I select the EAM profile and use that until I am
fairly
	> happy with the image.  Then, if I want to use another paper, I
select
	> that 'profile' within the soft proof set-up.  Of course the
image on
	> screen changes to what it will look like on the new paper and
I have to
	> edit the image again to make it look like I want it to on the
new paper.
	> Would it be  equivalent, in terms of matching the print on
different
	> papers to the screen, to edit the image is some default space
like
	> gamma 2.2 and then use the 'convert to profile' function in PS
to
	> convert the image to these same  paper specific profiles just
before
	> printing.  That way I would only have to edit the image once.
As long
	> as the profiles I create are good, I can print the image on
any paper I
	> use without re-editing?
	> This may be obvious to many, but I find the whole color
	> management/calibration thing a little baffling.  There seems
to be an
	> endless number of ways to get it wrong.
	> Kevin
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=212804.2460941.3878106.2273195/D=egroupweb/S=1705
019182:HM/A=810327/R=0/*http://geocities.yahoo.com/ps/info?.refer=blrecs
019182:HM/A=810327/R=1/*http://geocities.yahoo.com/ps/info?.refer=blrecs
<http://us.adserver.yahoo.com/l?M=212804.2460941.3878106.2273195/D=egrou
pmail/S=:HM/A=810327/rand=128796172>
	Please visit the Group Homepage to check the Files, Bookmarks,
Polls and other resources as they are often being updated. The page is
at:
	If you wish to receive no emails or just a daily digest, or you
wish to unsubscribe, please edit your Membership preferences by visiting
this same page.
	- As threads develop, trim off excess portions of earlier
messages to keep them short.
	- As the topic of a thread changes remember to change the
subject header.
	- Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
	- Before posting a question, search the message archives and the
various resources on the homepage.
	Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <http://docs.yahoo.com/info/terms/> .
2002-10-21 by Tyler Boley
--- In DigitalBlackandWhiteThePrint@y..., "Jonah, Jim"
etc. etc....
Man, there is a lot here that needs to be corrected or at least
addressed. Suffice it to say for now that I believe the original
question involved custom grayscale dotgain curves used as preview
and/or working gray spaces.
I would encourage the original poster to go ahead and pursue his ideas.
Tyler
