CFS ink levels change?
2002-10-24 by thronxx
Hi to all,
Could it be my imagination that, when I check ink levels using
the Epson utility for my 1280, the ink levels appear to get lower?
That sort of thing is not supposed to happen with a CFS/CIS.
Any comments, or do I need a little rest?
Many TIA, Jeffrey
Re: CFS ink levels change?
2002-10-24 by Jeff Randall
Jeffrey:
You probably are not halucinating from lack of sleep.  With the
original CIS from NoMoreCarts (Niagra), you have to turn the printer
off and back on to reset the chip.  With the MIS CFS, you need to
manually reset the chip.
Jeff Randall
--- In DigitalBlackandWhiteThePrint@y..., "thronxx"
<happy.eyeball@v...> wrote:
> Hi to all,
> Many TIA, Jeffrey
2002-10-24 by jim hayes
The CIS uses read only chips that always read full, with a little
printer of/on tweaking. The CFS requires the f-16 chip resetter from
MIS. Or you could use an old Russian buggy DOS app that works in Win98
with a parralell port ONLY that is cheaper, both available from MIS.
Jim H.
--- In DigitalBlackandWhiteThePrint@y..., "Jeff Randall"
<jrandall@c...> wrote:
> Jeffrey:
> Jeff Randall
> > Hi to all,
> > Many TIA, Jeffrey
Oops,
That's what happens when you selectively read instructions.
Got it. Chip resetter. Works fine.
My assumption was that levels always read full. I guess the purpose
of the chip is to indicate a new/full cart, not to indicate levels.
The printer does that.
Many thanks, Jeffrey
> Hi to all,
> Many TIA, Jeffrey
