[Digital BW] Digital Rave / PhotoEast Meeting
2002-11-02 by Paul Roark
Sounds like this was a great meeting. >... >The most common weakness in terms of print quality >was lack of separation in deep blacks. ... The rod coating that Robert and I are now doing allows one to address this. With the deeper blacks (density over 2.0) one can increase the deep shadow contrast and separate the tones, with dramatic visual impact. Note that my lightly-selenium-toned Kodak Polymax Fine Art silver prints have a dMax of only about 1.9. So, one easy coat on an Eclipse Satine and we have a visibly-greater dynamic range than the silver prints. Add the digital controls that allow us to selectively increase the contrast of the deep blacks, and, well, the silver print just cannot compete on that basis any more. Another problem that the coating addresses is the physical deterioration that prints can suffer. In the preservation projects I'm involved with the poor physical condition of the prints is often the worst problem. Pigmented inks are going to be hit in spades with this. Those particles on the surface of the paper are very vulnerable. One reason the traditional silver print has done relatively well is that the image-forming particles are embedded in gelatin. This protects them to a certain degree. The coatings (acrylic or polyurethane) we are now using to fix the carbon particles to the paper and encapsulate them are a lot tougher and less permeable than gelatin. The resulting print surfaces are so tough I can clean them with a damp paper towel. With a tough, cleanable surface, this now opens up display without glazing. When the glass/plexiglass and resulting reflections are removed, the dynamic range of the print that is, as a practical matter, accessible to us in most lighting situations expands dramatically. In most actual display conditions, an un-glazed, coated, carbon-pigment print will have a very significantly better dynamic range than a glazed silver print. The unglazed, high-dynamic-range prints we can now produce and display will speak for themselves. Paul http://www.PaulRoark.com
