[Digital BW] solvent?
2002-11-04 by Paul Roark
Matt, >... MIS FS inks ... >Question: >there is a solvent smell from the prints for a bit after printing. >I didn't think these were solvent based inks. The black ink has been described to me as a "co-solvent" ink. It has a strong smell. There is a volatile solvent in there, probably in addition to water. As I understand it, the co-solvent is one reason this ink does so well in terms of blackness and longevity compared to many other black pigmented inks. I do, however, think that the more volatile co-solvent could lead to more problems with clogging and evaporation through CIS lines if the printer is used infrequently. For that reason, when I designed the variable-tone/mix inkset that MIS now sells, I made sure it would also work with the older, non-co-solvent MIS archival black. It is less black, but prints well with the vm curves, especially if you put a "94" in the "95" box of the Epson driver "Transfer Function." The MIS VM and FS blacks are the same. This ink is also essentially the same as the original PiezoBW black ink. Paul http://www.PaulRoark.com
