Switch to FS inks, was little dots through loupe
2002-11-11 by Kemal Delic
Paul, I am printing with MIS WM-Sepia inks on Epson 3000 printer. I would like to buy FS-N inks to try with the Cone driver. If I understand right I shall only buy yellow position ink and save some money. True? Sorry for unnecessary question but I must be sure. Best, Kemal ------------------------------------------------------------------------- Paul Roark wrote:
> > There is no other variable-mix/tone inkset that will be any better. The > gray inks in the vm-s are the fs-n inks. It you use the vm-w standard MIS > VM warm curve, then you'll see what the midtones and highlights with that > inkset will look like. It's slightly cooler than the vm-s. > > Paul > http://www.PaulRoark.com >
