Misleading head alignment, also splattery printing
2002-11-15 by Euphy
Hallo all, I'm using an epson 1290 and have for a while noticed that the
magenta channel (and sometimes the cyan) creates a very light random spray
around, either side and a little above where it's told to. It's only really
noticable on contrasty coloured/white edges, but has begun to concern me,
especially since I've noticed my black is seriously out of alignment too
(the magenta channel is rather fuzzy-edged as well, though this could be a
more extreme version of the spattering problem).
Whereas I can at least put the splatteriness down to dirt or something , the
black problem is odder, since a head alignment process says they are fine -
in the test sheet line 8 is the best in all three b/w prints, as it should
be, and 5 is best in the colour prints, also as it should be. But the black
text that labels them is out of alignment, very clearly. It's much improved
if I turn off high speed printing, but still not perfect.
I've had a look through the archives, and searched a few other groups and
the net generally, but I can't find any useful references to splattery
output, and don't really know how to search for
unalignable-heads-when-the-printer-says-they're-ok.
Any ideas, any experience with problems like this?
sandy @ www.euphy.co.uk
Re: Misleading head alignment, also splattery printing
2002-11-16 by jim hayes
I'm going to suggest two possibilities that I really don't have a lot
of confidence in...so consider it a shot in the dark to check for, and
maybe someone else will have a better idea.
1) Dirt under the head deflects the stair pattern in a nozzle check,
also is responsible for blobbing. Corrected by paper towel under the
head trick.
2) You don't state if you use a CIS/CFS or carts, but if the cart
clamp has been removed for these, or if the carts aren't simply seated
well for some reason, I had heard somewhere third-hand that this
causes overspray. I don't know, maybe if you have ink caked up at the
bottom of nipple you would get the same effect of cart rising, though
I think the chip connector would start getting upset at this point and
give you a red light.
Not likely, but easy to check....
Jim H.
spray
really
concern me,
too
could be a
something , the
fine -
should
the black
improved
groups and
splattery
