[Digital BW] Meyer rods; Paul's technique
2002-11-16 by Paul Roark
Matthew,
You wrote:
>...if I'm
>reading your posts and the
>archived files correctly, you're actually just
>pushing the rod across the image -- using it to
>apply, rather than pull off the excess?
Yes.  The coating is put above the image first, using a syringe.  Then the
rod is used to "push" (I actually pull the rod toward me) the coating
material across the print surface.
http://www.PaulRoark.com
Nice mess was: [Digital BW] Meyer rods; Paul's technique
2002-11-17 by thronxx
Hi All,
Tried Paul's coating technique - glass, poly, wire rod. Ended up
with a lumpy mess but enjoyed every minute of it. :-) Saw what I did
too much of and too little of.
Does the dmax justice, that's for sure. I like it. Just have to be a
bit less... agressive. Many thanks, Paul. Pardon me while I peel my
hands...
Cheers, Jeffrey
Re: [Digital BW] Meyer rods; Paul's technique
2002-11-18 by Robert Morrison
Mathew,
This is a common technique in ink/pigment labs where we use the Mayer rod
for testing small samples.  I then adapted this for use with coatings for
our prints.  It works well up to about 24" wide.  Beyond that I think it
will be difficult to manage the rod without a specially built rod holder.
The key with a rod coating is using the proper rod (wire) size for the
viscosity of the coating that you are applying...this in turn needs to be
balanced with the polymer solids in the coating.
Robert
On 11/16/02 3:14 PM, "Paul Roark" <paul.roark@...> wrote:
> Matthew,
> You wrote:
>> ...if I'm
> Paul
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other
> resources as they are often being updated. The page is at:
> page.
> them short.
> &amp;amp;quot;flames.&amp;amp;quot;
> resources on the homepage.
2002-11-19 by Jerry Olson
Matthew, if you can't get an extremely deep black equal to silver prints
with epson dye inks on photorag paper or epson papers, you are surely
doing something wrong.  You may have a setting somewhere that makes all
the difference, Double check all of them !
Jerry
Matthew Born wrote:
> Very interesting. I, like many of us, it would seem, love the black density
> from dyes but would very much like to find something that lasts a bit
> longer. I also like the general look and feel of Photo Rag and Satine, but
> even with my dyes and lots of tweaking they seem awfully light. There's a
> lot of uneven surface area there for the light to bounce around in; varnish
> would do the trick. If a 2200 ever shows up on our (U.S) shores again, I
> might jump in and give the Mayer rod a whirl. Or I could varnish a dye print
> and get some *really* interesting results...I'm assuming that, unlike the
> commercial offset inks I'm used to, inkjet dyes would smear like butter, no?
> Or I stand under Mark's window and wait for that 9600 to come sailing out. I
> figure if the blacks are that light, it won't hurt too much when it lands on
> me.
> Thanks again,
> Matthew
> >>Mathew,
> Robert
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
> - Before posting a question, search the message archives and the various resources on the homepage.
