Info for Windows Photoshop users that may be of use... (particularly NT, 2000 and XP users)
2002-11-18 by Editor P.O.V. Image Service
Some time back, I noted, that you can alter the "priority" of PShop from
the task manager OR you can
change it's default priority in the registry (I don't recommend the
latter unless you intend to lower it's priority).. You can also use
command line options in your shortcut to load PShop with a higher priority.
I use the following (understanding that both my Windows and PShop
directories are on my D: drive) :
Target:  D:\WINDOWS\system32\CMD.EXE /C "start /HIGH Photoshp.exe"
Start in: "D:\Program Files\Adobe\Photoshop 6.0"
where I use "/HIGH", there are other options:
/REALTIME
/HIGH
/ABOVENORMAL
/NORMAL
/BELOWNORMAL
/LOW
Unfortunately you cannot set CPU affinity via a command line option like
that..  Some aftermarket add-ons that supposedly will do so seem not to
like PhotoShop...
Keith
"Just some guy," and founder of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSONx7x_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
RE: [Digital BW] Info for Windows Photoshop users that may be of use... (particularly NT, 2000 and XP users)
2002-11-18 by Tim Atherton
can you repost the earlier info about the task manager?
thanks
tim
> From: Editor P.O.V. Image Service [mailto:editor@...]
> Sent: Monday, November 18, 2002 11:19 AM
> Subject: [Digital BW] Info for Windows Photoshop users that may be of
> priority.
> /REALTIME
> /HIGH
> /ABOVENORMAL
> /NORMAL
> /BELOWNORMAL
> /LOW
> like PhotoShop...
> Keith
> Publications), at:
> guys"
> Please visit the Group Homepage to check the Files, Bookmarks,
> Polls and other resources as they are often being updated. The page is at:
> If you wish to receive no emails or just a daily digest, or you
> wish to unsubscribe, please edit your Membership preferences by
> visiting this same page.
> - As threads develop, trim off excess portions of earlier
> messages to keep them short.
> "flames."
> - Before posting a question, search the message archives and the
> various resources on the homepage.
Re: [Digital BW] Info for Windows Photoshop users that may be of use... (particu
2002-11-18 by Keith Krebs
You can alter the "priority" of PShop from the task
manager OR you can change it's default priority in the registry (I
don't recommend the latter unless you intend to lower it's priority)..
To change it while PShop is already running..
Simply open the taskmanager by invoking "taskman" from the "run"
dialog, or.. by using CTRL-ALT-DEL
Go to the "processes" tab...
When you find Photoshp.exe, right-click on it and choose the "set
priority..." option..
Choose a priority- you can alter this as needed if you decide to load
/ unload other processes/programs that may need more resources.. As an
example, you might lower it while PShop runs batch actions and you do
other work, then raise it back up when you are doing image editing..
Unless you are running two or more CPUs I strongly recommend avoiding
"realtime"..
Yes, you can change the priority while PShop is running (if you find
you want more or less cpu cycles devoted to it)..
If you have more than one CPU, you can consider setting a CPU affinity
as well, but since some filters actually multi-thread,  you would
likely be losing performance by doing so..
Keith
Re: Info for Windows Photoshop users that may be of use... (particularly NT, 2000 and XP users)
2002-11-19 by Editor P.O.V. Image Service
> from the task manager OR you can
> priority.
> /REALTIME
> /HIGH
> /ABOVENORMAL
> /NORMAL
> /BELOWNORMAL
> /LOW
> like that..  Some aftermarket add-ons that supposedly will do so seem
> not to like PhotoShop...
> Keith
I am attaching my ENTIRE sig line to this copy for a reason.
IF anyone forwards, reprints, or cites this command line technique for
starting PhotoShop at a particular priority, I would simply ask that I
also be cited as the ORIGINAL source for said information.
This particular tip IS NOT one I have seen on any Photoshop website or
in any PhotoShop book as of yet abd therefore would sincerely request
that if the technique is referred to, described, or referenced, I be
given the simple common courtesy of credit for suggesting the technique
be used  for running PhotoShop under Windows, and for explaining how to
do so. (if possible, I would ask that I please be cited by name with a
link and reference to the 2000+ member EPSON printer group I founded,
at: http://groups.yahoo.com/group/EPSONx7x_Printers)
My publishing the particulars of this idea on this forum in no way
indicates that I have relinquished any copyright inherent in said content.
I have no objection to the idea being added to a compendium of
 PhotoShop tips online, or in book form, etc. I simply ask that I be
appropriately credited.
Thanks.
Keith
Publications), at:
guys"
CONFIDENTIALITY & COPYRIGHT NOTICE:
This e-mail message, including attachments and contents, is © Copyright,
Keith Krebs, 2001-2002, All Rights Reserved. It is expressly for the
sole use of the intended recipient and may contain confidential and
privileged information. Absent the express written authorization of the
author, any unauthorized review, use, disclosure, transfer, or
distribution is explicitly prohibited and taken at your own risk. If you
are not, or are unsure whether you are, the intended recipient, please
contact the sender immediately and destroy all copies of the original
message. Violations will be prosecuted to the FULL extent allowed under
applicable civil and criminal law. Imagery published or distributed in
violation of these conditions shall be subject to a $1500/image
liquidated damages charge, in addition to any applicable Copyright
violation penalties.
POV IMage Service Banner
{ The P.O.V. Image Service Website is still at http://www.p-o-v-image.com/ }
