Re: [Digital BW] Uncool (was "Ultrachrome Inks Issues and Concerns")
2002-11-25 by Editor P.O.V. Image Service
Lawrence Smith wrote: >On 11/25/02 10:31 AM, "Bobbo" <bobbo924@...> wrote: > > > >>The color shot on the photo glossy paper clearly shows this >>so-called metamerism, AKA bronzing, AKA all sorts of other things. >> >> > > >Bronzing and metamerism are not the same things at all. If you search some >archives you can find out what matamerism really is and also good >descriptions of 'bronzing'. > > > Not to be a pan in the butt.. BUT... Metamerism can be much higher with certain colorants in areas where bronzing occurs, simply because there is more ink than the media can properly absorb.. You can essentially have ink on ink instead of ink on media (ad nauseum), and that can accentuate metamerism as a result of these "piled up" colorants. So, he COULD be seeing both. That said, metamerism and bronzing ARE two different phenomena. Keith "Just some guy," and founder of the Multiverse's largest EPSON printer User Community (highly recommended by Vogon Poets and MegaDodo Publications), at: http://groups.yahoo.com/group/EPSONx7x_Printers/ "For the rest of you out there, the secret is to bang the rocks together guys" [Non-text portions of this message have been removed]
