SoftProofing the MIS VM and MIS VM Sepia Inksets..
2002-12-01 by Editor P.O.V. Image Service
Here I was  searching for some info on softproofing in general and I
stumble on Dan Culbertson's page on softproof  creation for Quads with
 Profiler Plus  at:
http://www.lincolninks.com/culbquads/CulQuad.html
I give it a general read, note the comments on using Tyler Boley's step
wedge and begin to wonder... Can I usefully combine this with the Tyler
Boley or Paul Roark curves and get myself some usable onscreen proofs?
I mean, it's all well and good to see a nice neutral greyscale image
onscreen, but if I'm actually printing a cold-tone or sepia image, it
would be REALLY nice to get a sense for color before I print it...
Well, after a VERY little bit of trial and error,  it turns out it can
be done quite easily... Not only that, it should work with any scanner
or spectro based profiling package.
First, as I would with any other inkset, I print a standard Profiler
Plus calibration chart,  scan it and create a high resolution profile..
You can tweak the profile if you want, but these narrower gamut inksets
tend to swing wildly when you tweak outside a very narrow range, so I
just go with the stock automated profile that was just created.,..
Now, take a greyscale image, and convert it to RGB.  Then in the
PhotoShop  "View Menu" choose "proof setup" followed by "Custom"..
 Select the newly created Quad Profile..  Be sure to Select the
"Preserve Color Numbers" in the dialog box.
Then in View select the "Proof Colors" to turn on the soft proof. If all
works, you should now have a pretty near neutral image onscreen, an RGB
mode greyscale image if you will... All well and good.
The fun part is to see what happens when you apply Paul or Tyler's
curves (for VM), or my curves (for VM Sepia) to this image... (Making
sure you use one of the No Color Adjustment curves)  Apply a curve to
the image... VOILA!  A softproof of the final image printed with the
color balance the curve defines..  Very nice, no more guessing about how
warm a "w" curve is compare to an "mw" curve..  No more guessing how
cold an "nc" curve will look when applied to a particular image!
In fact, you can now, with this and the info at the bottom of Paul's
page on "separation curves examples" you should be able to actually
interactively play with some home brewed curves.  In fact, one could
even create split toning curves this way before printing tests (I'm sure
they'll still need subtle tweaks)..
Anyway, the bottom line is  that instead of seeing the garish colors
induced by the application of the curves,  not only do the curves
produce the desired final color temperature in the print, but you can
pre-visualize that color range onscreen...  I hope this will be of value
to someone..
Keith
"Just some guy," and founder of the Multiverse's largest EPSON printer
User Community (highly recommended by Vogon Poets and MegaDodo
Publications), at:
http://groups.yahoo.com/group/EPSONx7x_Printers/
"For the rest of you out there, the secret is to bang the rocks together
guys"
CONFIDENTIALITY & COPYRIGHT NOTICE:
This e-mail message, including attachments and contents, is © Copyright,
Keith Krebs, 2001-2002, All Rights Reserved. It is expressly for the
sole use of the intended recipient and may contain confidential and
privileged information. Absent the express written authorization of the
author, any unauthorized review, use, disclosure, transfer, or
distribution is explicitly prohibited and taken at your own risk. If you
are not, or are unsure whether you are, the intended recipient, please
contact the sender immediately and destroy all copies of the original
message. Violations will be prosecuted to the FULL extent allowed under
applicable civil and criminal law. Imagery published or distributed in
violation of these conditions shall be subject to a $1500/image
liquidated damages charge, in addition to any applicable Copyright
violation penalties.
POV IMage Service Banner
{ The P.O.V. Image Service Website is still at http://www.p-o-v-image.com/ }
