Ink Chemistry Refresher
2002-12-05 by Jeff Randall
All this water and ammonia discussion has taken place without the context as to the kind of ink (especially the ink pH). The ammonia makes the cleaning solution basic (high pH). This works well with basic (high pH) inks. If the inks are acid based, then **BIG TROUBLE** with water and ammonia cleaning solution. Inks like MIS FS and VM and the original PiezoBW inks are basic. Ammonia and water work well. It's my understanding that some Lyson inks are acidic. If you are not 100% sure, I suggest dripping a few drops of your ink into the cleaning solution to see if it disperses (good behavior) or clots (bad behavior). Jeff Randall
