Re: [Digital BW] Coatings -- Mayer rod source
2002-12-11 by Paul Roark
Don,
>So where can one purchase a mayer rod? Diversified isn't selling to
>rank and file consumers. ...
Diversified just was not able to service small accounts profitably.  So, MIS
has been set up as the retail source.  I don't know what their prices or
availability will be.
>Paul Gardner Company sells an 8 inch wood for $73 + shipping! OUCH!
Maybe we ought to look for more springs that can make good substitutes.
http://www.PaulRoark.com
2002-12-14 by rbehr2001 <rsbehr@hotmail.com>
Paul,
How about hand wrapping straight rod? I have a lathe that might
simplify the process. I think I'll give it a try. What dimensions
would you advise for coating 13" wide EAM? From what I've read
1/2"x16" rod wrapped in .030" wire over 15". One problem will be to
obtain perfectly straight rod. Also anchoring the ends securely with
no increase in diameter. It doesn't seem like materials are critical.
All stainless would be nice but I can't imaging adverse chemical
reactions occurring with copper or carbon steel in the short period
that they are in contact with the coatings. I'll hunt for materials
this morning.
Bob
<paul.roark@v...> wrote:
> Don,
profitably.  So, MIS
prices or
substitutes.
> Paul
2002-12-14 by Paul Roark
Bob,
I suspect a lathe and some wire or the right gauge will do it.  The 1/2 inch
stainless steel rod has small holes drilled in it at the ends of the wrapped
section.  The ends of the wires go through these and are soldered.
> What dimensions
15" or winding will do.  Then leave 2" on each end as handless.
> From what I've read
Give yourself some bigger handles/ends.
> One problem will be to obtain perfectly straight rod.
I'm not sure where one would get 1/2 inch stainless, or how most of us would
drill or solder it.
Since the paper will hold the rod a little off the glass, some increase in
thickness will be OK.
Good luck.  I think this should be doable.
Are MIS prices reasonable?
____________________________________________
> Don,
profitably.  So, MIS
prices or
substitutes.
> Paul
Re: Coatings -- Mayer rod source
2002-12-18 by rbehr2001 <rsbehr@hotmail.com>
Completed my first rod. It actually went much smoother than I
expected. Although I used a drill press and a lathe in the process,
it could probably be done with hand tools.
I only used the lathe to support and turn the rod. The slowest
rotational speed seemed to fast to control so I turned it by hand.
I'll try power next time. It should be possible to jury rig something
to hold the rod while wrapping; or it could be done by two people.
Basically you need to be able to turn the rod while maintaining
tension on the wire. Either four hands or mechanical assistance. I
had to fuss a bit to get the right combination of wire tension and
angle of the wire to the rod to pack it tightly without over-
wrapping. But it's a fairly forgiving process at least with the soft
copper wire I used.
Holes in the ends should not be a problem with a vise, a hand drill,
a sharp drill bit and a center punch. Or forget the holes and
overwrap and epoxy outside the working area. I used holes with solder
on one end and epoxy on the other.
The 1/2" steel rod is available at Home Depot in 3 ft lengths. When
cut to an overall length of 23" (for 17" paper when I get my 3000,
another topic)there was a slight bend in the rod. Using feeler gages,
I estimate it was about .004" from straight. As I understand the
coating process, the rod is not allowed to turn, so it could be held
in an orientation that eliminates the bend. Or, I was wondering if I
could use the slight bend to more evenly distribute the coating.
Since coverage seems to get thin toward the ends, a little extra
clearance out there might help. Have to experiment.
Now for the questions. I used .025" wire because that's what I had.
With EAM, I'm getting slight but quite unacceptable vertical banding
in the direction of coating. Probably not enough coating. I'll
experiment with more coating material at the top but I might have to
make another rod with thicker (.030"?) wire. Another thought; I made
the rod long enough to coat the widest material anticipated, 17".
Since I'm only doing 8" wide tests, could the extra weight per unit
of contact be thinning out the coating? Do we need sets of rods of
different length and different wire diameter to do different material
of different widths? That would be different ... and rather expensive
if you were buying them.
Bob
> Bob,
1/2 inch
the wrapped
> > What dimensions
> > From what I've read
us would
> drill or solder it.
increase in
> Paul
> > Don,
to
> profitably.  So, MIS
> prices or
OUCH!
> substitutes.
> > Paul
