Epson Archival quad
Epson Archival quad
2002-12-12 by Paul Roark
The FS/Piezo-compatible quad I've mixed from Epson Archival black (a 7500
cart) looks to be a very interesting and neutral inkset.  Assuming the Epson
claims of longevity are true, this could be a 200 year inkset.  Unlike the
color Archival pigments, the all-black-ink quad prints show no significant
metamerism.
The X-Rite readings of representative 21-step test-strip midtones of my "Eps
Arc FS2," printed with the Piezo driver, EAM profile, on my 1160 are as
follows:
Paper	%	Cyan	Magenta	Yellow	Visual
Epson Archival Matte
	25%	.34	.35		.35		.35
	50%	.63	.64		.63		.63
	75%	1.02	1.02		1.02		1.02
Legion Photo Matte
	25%	.35	.36		.35		.36
	50%	.63	.63		.61		.63
	75%	1.02	1.02		1.00		1.02
Eclipse Satine Bright White
	25%	.29	.30		.29		.29
	50%	.56	.56		.55		.56
	75%	.88	.87		.86		.88
The magenta reading being slightly above the average of the cyan and yellow
is typical of selenium-toned silver prints (and the PiezoTone selenium).
Cool shadow tones are also typical of selenium-toned prints.  With the MIS
Matte Black ink that I currently have in the printer, this is carried right
through to the 100% black position on both LPM and Eclipse.
The "Eps Arc FS2" mix is as follows:
	Cyan = 50% Arc K
	Magenta = 11% Arc K
	Yellow = 5.13% Arc K
These percentages need a bit of fine tuning, but, as can be seen from the
density readings, they are very close.  (The 75% readings will probably
increase 0.01 as they age.)  I'm not sure what Piezo profile people use for
Eclipse and LPM, so I just used the EAM profile.
The Epson Archival black can be harvested from large format cartridges.   I
used the standard MIS clear base to dilute the black ink.
While I have no fade tests yet -- and the results of those will be affect
which direction I go -- I tentatively think that a quad based on the Epson
Archival black is in my future.  What black-position ink I will use is too
early to tell.  Fade tests and paper choice are major variables there.
The pure Epson Archival K-based midtones look great to me, and the use of
Epson Archival inks (without the baggage of metamerism and weak blacks,
since that position is wide open) could be significant.  Once diluted, the
prices are competitive.
http://www.PaulRoark.com
Re: [Digital BW] Epson Archival quad
2002-12-12 by Robert Morrison
> metamerism.
> follows:
> 25%    .34    .35        .35        .35
> 50%    .63    .64        .63        .63
> Legion Photo Matte
> 25%    .35    .36        .35        .36
> 50%    .63    .63        .61        .63
> 25%    .29    .30        .29        .29
> 50%    .56    .56        .55        .56
> 75%    .88    .87        .86        .88
> Cyan = 50% Arc K
> Magenta = 11% Arc K
> Paul
Paul, what the dmax for this ink on these papers?  As I recall it was quite
poor.  In fact, my memory suggests that all papers were actually less than
1.5. I really receive proof prints from a printer that uses a 10000 (same
inks as the 7500) and the blacks are always very poor.
Also, the 200 year estimate is certainly a bogus figure.  I know that these
inks do fade in sunlight quite quickly...but I haven't actually seen CYMK
fades so I don't know specifically about the black.  But it will be
interesting to see how they do in your fader compared to the current
competition.
Robert
RE: [Digital BW] Epson Archival quad + coatings
Robert,
I don't think anyone will use the Epson Archival black ink in the black
position for matte paper.  That position is open.  That is one reason I
didn't report the 100% patch.  I currently have the MIS Matte Black in
there, and it looks terrific on Eclipse and LPM.  However, I have no fade
test results for the MIS Matte Black, and Epson's Matte Black is much darker
on EAM.
So far the Epson Matte Black is the most lightfast black ink I've tested.  I
assume the Epson Archival black is better, but I doubt it's enough better to
warrant its use on matte papers.  Ongoing fade tests will be needed to see
what black ink is best.  I don't have any of Cone's latest "Archival" black
ink, but it would be one I'd like to test also.  So far, I've seen no
reliable data on it.
I might note that Epson Matte Black has some negatives.  It appeared to
cause vertical banding on my 1160.  It also is very warm, making it great
for a warm inkset, but not so great for a neutral or cool one.
Of course, all inks fade.  I suppose even silver prints fade.  (I'll
eventually make some silver test strips for comparative fade testing.)
However, for indoor display, I think the Epson Archival inkset is probably
the most lightfast there is that is feasible on the printers we typically
use.  I have never seen any reports of any indoor inkset that can beat or
even match it.  I suspect the coating of the particles is one key to this
performance.  While carbon may be relatively stable, it clearly oxidizes.
An oxygen barrier should increase it's fade resistance.
I was hoping that the coatings we are experimenting with would be a
substitute for the Epson encapsulation.  However, my fade tests as well as
other information on the nature of the coatings makes me doubt that any
water-borne coating will match what Epson has.  The water-borne acrylics, in
particular, appear to have no significant gas or moisture barrier
properties.  The cross-linking of polyurethanes should help, but the extent
of such in single-component PURs may be too little to have much effect.
Also, the water-borne coatings are probably just laying on top of the
particles instead of surrounding them.  Thus, the gas and moisture can get
to the pigments through the paper.
The difference in the adhesion statistics between the water and
solvent-borne coatings is dramatic.  This measure, from what I can tell,
indirectly tells us the extent to which the water-borne dispersions are not
penetrating much more than the pigment particles themselves.  They just lay
on the surface.
Of course, the sprayed solvent-base PURs I've tried have also had no
significant impact on fade resistance.  It may be that a low molecular
weight coating like Gamvar would have some chance of doing the job.
Have you tried any of the solvent based coatings directly on the paper?  I
have the impression there are problems of uneven paper penetration and
blotchiness.
At any rate, while I have no fade test results yet, if I were a gambling
person, I'd bet that the Epson Archival black-based midtone quad pigs set
the standard for now.
_______________________________________________
  Sent: Thursday, December 12, 2002 10:13 AM
  Subject: Re: [Digital BW] Epson Archival quad
7500
Epson
significant
  > metamerism.
"Eps
  > follows:
  > 25%    .34    .35        .35        .35
  > 50%    .63    .64        .63        .63
  > Legion Photo Matte
  > 25%    .35    .36        .35        .36
  > 50%    .63    .63        .61        .63
  > 25%    .29    .30        .29        .29
  > 50%    .56    .56        .55        .56
  > 75%    .88    .87        .86        .88
yellow
MIS
right
  > Cyan = 50% Arc K
  > Magenta = 11% Arc K
for
I
affect
Epson
too
of
  > Paul
quite
these
  competition.
  Robert
page.
them short.
  - Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
resources on the homepage.
Re: [Digital BW] Epson Archival quad + coatings
So you don't trust the RIT test data that cone published?  Admittedly I will
feel better about the fade once we have it in your fader...but I don't see
any reason not to trust the RIT numbers...and they seem pretty clear as
compared to the MIS-FS black...of course he wasn't running Ultrachrome Matte
Black.
Robert
Robert,
I have not seen the RIT numbers.  Do you have a link to them?
  Sent: Thursday, December 12, 2002 11:51 AM
  Subject: Re: [Digital BW] Epson Archival quad + coatings
tested.  I
better to
see
black
will
Matte
  Black.
  Robert
page.
them short.
> blotchiness.
Yes, I've tried all of these including Gamvar and the Goldern MSA varnish,
and yes they do not work unless you seal the paper first with a water-based
product first.  In addition Gamvar will stink up a house to the point that
your head spins in about 15 minutes of use.  With the seal coat they give a
nice high gloss finish...but it can take you days to coat a single print
because they require several coats with 6-12hour dry times...not an option.
Robert
Re: RE: [Digital BW] Epson Archival quad + coatings
2002-12-12 by Ernst Dinkla
Sent: Thursday, December 12, 2002 10:09 PM
Subject: Re: RE: [Digital BW] Epson Archival quad + coatings
> In the Conservation and Archives communities, this is exactly one of
> the points being made in developing standards for digital archiving.
> Silver prints do fade, even when kept in ideal conditions. Silver
> prints now in collelctions have only had their deteriation slowed down
> by being stored in ideal conditions - many older ones are now
> deteriorating noticably, and nothing much else can be done to prevent
> it - they are reaching the end of their life and will eventually
> deteriorate so far as to be unusable - be it after 75, 100, 125 or 150
> years.
In the end it will become clear that we never should have abandoned the
asphalt process of Niepce.
The first and last print on earth.
Ernst
2002-12-12 by Tim Atherton
years.
>>(I'll eventually make some silver test strips for comparative
>>fade testing.)
> Silver prints do fade, even when kept in ideal conditions. ...
The copying, restoring, & printing I do for our little museum and others
seem to mostly involve albumen prints.  They are often very faded after 100
years.  Copying can restore the contrast and make a huge difference in
appearance, but every iteration of copying and restoring is going to lose
some information.
I must say, however, that the fading is easier to deal with than the
physical damage that has occurred to many if not most of the old prints that
I work on.
One reason for my interest in the toughest possible inkset & coating is in
the hope of getting something that will last as long as possible in this
context.
>abandoned the asphalt process of Niepce.
Hmmm, an asphalt inkset ...
On 12/12/02 12:17 PM, "Paul Roark" <paul.roark@...> wrote:
> Robert,
> Paul
They are the numbers that we were all talking about a month ago.  The fades
were done by RIT.  They are all published in the files section on the
piezography3000 list.
http://groups.yahoo.com/group/piezography3000/files/400%20Hour%20Xenon%20tes
ts/400hour-PhotoRag.pdf
ts/400hour-EPSON_EAM.pdf
Robert
Robert,
Thanks for the link.
I don't think those are RIT numbers.  I thought these were tests Cone did
in-house.   I recall the question of what if any filter Cone used on the
Xenon lamp.  The tests say "UV light."  Most use a filter with these lights
that emulate window-filtered sunlight.
At any rate, these tests do show that the "Museum" black performs better
than the FS/VM black at least with this light.  It's definitely an ink I'll
want to test.
  Sent: Thursday, December 12, 2002 2:16 PM
  > Robert,
  > Paul
fades
  Robert
page.
them short.
