repacement for CFS foam pads??
2002-12-13 by knarfi_1 <fh.gross@sympatico.ca>
the little foam pads that I have to remove/replace on my MIS CFS
system to reset the low ink level are worn & squashed - is there
something else others are using thart is more durable or easier ?
thanks
Frank
Re: repacement for CFS foam pads??
2002-12-13 by John Vitollo <johnnyv@comcast.net>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "knarfi_1 <
> thanks
> Frank
Use those foam air-plugs - find in any good hardware store.
2002-12-14 by jim hayes <jimhayes@frii.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "John Vitollo
> > thanks
> > Frank
I think you mean the old trick of replacing with compressable foam EAR
plugs, no?<g>
Jim H.
