Re: [Digital BW] Epson Site Updated -- MSDS URLs
2002-12-20 by Thomas Fors
From: "Paul Roark" <paul.roark@...> To: "DigitalB&WPrint" <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Thursday, December 19, 2002 11:08 AM Subject: [Digital BW] Epson Site Updated -- Archival ink > > Do you have a URL for the MSDS sheets? > Here are the URLs for the various MSDS sheets: 2200 UltraChrome Photo Black Cart.: http://files.support.epson.com/pdf/msds/t034120.pdf 2200 UltraChrome Matte Black Cart: http://files.support.epson.com/pdf/msds/t034820.pdf 2200 UltraChrome Light Black Cart: http://files.support.epson.com/pdf/msds/t034720.pdf 10000 Archival Black Cart: http://files.support.epson.com/pdf/msds/t511201.pdf The MSDS sheets are specific to each cartridge type, and while I'd imagine the 2200/7600/9600 MSDS sheets should all be the same, I haven't verified this. If you know your cartridge's part number, you can probably substitute it in the above URLs and find the MSDS sheet. If not, go to www.epson.com/northamerica.html click on "drivers & support" in the left column click on "Printers..." in the center column find your printer in the list and click on it in the right column, click on MSDS To answer the question about dyes in the archival inks, they lump dyes and pigments together into a single category titled "Proprietary dyes and pigments." So, it doesn't necessarily mean there is dye in there, and it doesn't tell you the split if there is a combination. --Tom
