scratch or banding?
scratch or banding?
2002-12-22 by Jeff Hargrove <jeff@jeffhargrove.net>
I am quite new to inkjet printing and I am not sure whether my
problem is what you would call banding.
Anyway, on all my prints, in the same position, I get a "white"
hair-thin line running virtical from top to bottom. Its position
is the same regardless of the print (ie the same distance from
the left edge of the paper) which leads me to  believe that
something in the printer is scratching my prints as they move
through the printer. I say scratch because there doesn't seem
to be any ink on  this very fine line. It can only be seen if the
light hits the print at a certain angle.
I did an alignment check, nozzle check and cleaning, cleaned the
rollers with  windex and air brushed them afterwards. This has
had no effect. I have tried several adjustments of the paper
thickness lever, no results either.
Is this a form of banding? I  would very much appreciate any help or
advice you could give me. I forgot to mention that I am printing on
a 1290 with generation 4 color inks.
Thanks
Jeff Hargrove
Re: scratch or banding?
2002-12-22 by Steven Karafyllakis <stevek@evcom.net>
Hi Jeff;
What we refer to as 'banding'is gapping in the ink spray due to
clogged nozzles, air bubbles in the head, or sometimes a very badly
misaligned head. It is always in the direction of travel of the
head. A vertical scratch like you describe is likely a rough edge
somewhere, or something stuck to the bottom of the roller arm
assembly, or perhaps a 'pizza wheel' that isn't turning. Run a piece
of paper through and watch the star-shaped wheels in the area of the
scratch to verify that they are rotating. One question: you aren't
by chance feeding the paper in horizontally, so that the 'left edge'
actually is the last strip to get printed before exiting the
printer? Dumb question, but often if there is not enough margin on
that last strip to hold it down while being printed, it pops up when
it leaves the last set of rear rollers, and the head itself can
scratch it. Happens mostly with small pieces of stiff paper.
Hope some of this helps.
Steve Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Jeff Hargrove
or
on
> Thanks
> Jeff Hargrove
Re: [Digital BW] Re: scratch or banding?
2002-12-24 by Jeff Hargrove
Thanks for all your help Steve, David and Jerry. I didn't get back to
you right away as I was under the weather yesterday.
I checked the pizza wheels, and they all are turing fine. I am
inserting the paper vertically. And just before doing the other tests
you recommended, an email from jnhugo stated that Legion Photo Matte
8.5x11 has fine lines running through its printing side. It is in fact
the paper I am using to do a lot of experimenting. I checked the
surface and indeed there are fine lines running through the surface and
even some kind of scrapping, it seems. This is a production problem,
not a printer problem. I did a check on some photo rag and there are no
lines at all. I am relieved to know that I don't have to return my
printer to epson! And I also learned something: I was assuming the
paper out of the box was good and didn't even think to check the
surface. If I had I would have saved myself a lot time and frustration!
Thanks again!
Jeff
jeff hargrove
photography
http://www.jeffhargrove.net
2002-12-24 by Jerry Olson
You know, it never occurred to me that the paper itself might be
defective.  Glad to learn this, it
could come in real handy someday.
Jerry
> Thanks again!
> Jeff
> jeff hargrove
> photography
> Please visit the Group Homepage to check the Files, Bookmarks, Polls and other resources as they are often being updated. The page is at:
> - Good manners are required at all time. No personal attacks or &amp;amp;quot;flames.&amp;amp;quot;
> - Before posting a question, search the message archives and the various resources on the homepage.
