I'm using Vmware Workstation on Windows XP. It's a commercial product
and sets up a virtual computer that acts like a regular computer in
every way. It's very stable and I have no problem running Redhat
Linux in a window on my desktop, it acts like a separate computer on
the network with it's own IP address and everything.
I allocated the USB port in my 2100 to VMware while Windows uses the
Firewire port so I can print using both operating systems without any
further changes.
Currently I'm using GIMP itself, but realize that it doesn't support
CMYK files, so I was planning to try outputting postscript directly
from photoshop to a file and printing from that.
Unfortunately I'm not yet familiar with the command-line syntax for
CUPS and Gimp-Print, and there's no good examples in the
documentation, so I expect to struggle a little bit before figuring
everything out.
The method you're describing sounds very useful for what I'm trying
to achieve, thanks! I'll let you know when I get it to work...
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, John Labovitz
<johnl@j...> wrote:
> On 1/1/03 8:43 PM, "danielstaver <daniel@p...>"
> <daniel@p...> wrote:
> > After spending the whole night installing Red-Hat linux on a
virtual
> > machine (I normally use windows) and compiling various packages to
> > get Gimp-Print to work I finally got to try how it would do BW
> > printing on the 2100.
> Wow, that's dedication! I'm curious -- is the virtual machine a
commercial
> product, or something that's free?
> Exactly how are you getting the image to gimp-print? Through Gimp
itself?
> > What I would like to do now is to somehow get Gimp-Print to print
> > using only the two blacks, but tint the image with one additional
> > colour. The Epson blacks are pretty warm, so I'd like to add a
small
> > amount of cyan to get a more neutral image. I would be grateful if
> > someone with more experience with Gimp-Print could guide me in the
> > right direction on how to do this.
> You might be able to do this by sending a CMYK file to gimp-print.
If you
> use the "Raw CMYK" output mode, you can control each of the main
ink colors
> separately. Note that gimp-print still handles the light-regular
crossover,
> so it's not truly a raw mode, but it's closer than sending RGB.
> Anyway, if you set up a Photoshop file to be CMYK, but have your
main image
> as grayscale on the K channel, and the "toning" on the C channel,
you might
> be able to make this work.
> Try this:
> - open your grayscale file (and do a Save As just in case!)
> - convert to multichannel mode
> - go to the Channels palette
> - duplicate the "Black" channel three times
> - convert to CMYK mode
> - select each of the M and Y channels in turn, and erase their
contents
> (I use command-backspace on my Mac)
> - tune the C channel as desired (using Levels or Curves)
> - print, making sure you specify "Raw CMYK" in the gimp-print
settings
> John Labovitz
> johnl@j...
> www.johnlabovitz.com
