MIS vs. Gen4 black - again
2003-01-05 by Stephen A. Tucker <stephentucker@hotmail
I have a set of MIS Variable Sepia on order.
Before I load my CIS system for first time - what
are the pros and cons of using the MIS black vs.
the Gen4 black?
Gen4 black is reported to be 25% dye and produces
more black density.
AFAIK - there is no compatibility problem. But what
about esthetics?  Longevity?
Thanks in Advance,
Steve Tucker
Re: [Digital BW] MIS vs. Gen4 black - again
2003-01-06 by Sam A. McCandless
I have two 1160s, Steve, one with MIS VM Sepia-Neutral (as I still
call it) in its NoMoreCarts.com CIS, the other with MediaStreet's Gen
4 C, M, and Y inks in its NMC CIS, but along with the VM black,
instead of the Gen4 hybrid or "blended" 75/25 pigment/dye black. I
swapped the Gen4 K out for the VM K because of reports on the
ArchivalColor list that the Gen4 black had faded in some
circumstances. If I didn't re-print a lot of old B&W family photos, I
don't think I would have bothered.
My guess is that my color prints suffer a little as a result of the
swap. But my guess also is that most of the resulting deficit in
black density can be profiled away at the ink-set level, i.e., that
the other inks can at least partly make up for the black being
lighter. I haven't had that printer profiled yet though. And in any
case, I take it that you're thinking about swapping the VM black out
in favor of the Gen4 K as a companion for your other S-N inks. If
there's a visible difference you don't like, my guess is that you can
adjust the S-N curves to compensate for it, but I wouldn't know where
to start.
Sam
Sam McCandless            samcc@...
>the Gen4 black?
>more black density.
>Thanks in Advance,
>Steve Tucker
