Re: [Digital BW] Polaroid's Dust & Scratches
2003-01-13 by Simon Lamb
Frank
I am using the Mac version but I guess the same would apply for the Windoze version as well.  The first thing to point out is that I nearly always have to tweak the sliders to get the right amount of dust removal.  There doesn;t seem to be any good default setting.  I use the image at 100% - 200% and then remove all the imperfections.  What you will find is that you will also lose detail and some highlights by using this filter.  To overcome this, I create a duplicate layer.  Then, with just the bottom layer visible, I apply the dust & scratches filter to the extent that I need to.  Then, I make the top layer visible and using the eraser tool, I work on the areas where I want to remove the dust & scratches, and avoid the areas where the highlights or detail would be lost.  When finished I flatten the layers.
All in all this is a tool that works but it can take a long time to get the best end result possible.  Long, but certainly less time than doing the whole process manually.  However, it is not the same as having dICE in the scanner software, which is definitely the best approach for dust and scratch removal.  The upside with the dust & scratches utility is that, by avoiding using dICE, you do not get any softening of the image at scan time.
Simon
  Sent: Sunday, January 12, 2003 11:16 PM
  Subject: [Digital BW] Polaroid's Dust & Scratches
  I cant quite get the hang of using Polaroid's Dust & Scratches
  program (free). Anyone using it that can offer a few tips, pointers
  or a tutorial ?
  http://www.polaroid.com/products/product_detail.jsp?PRODUCT%3C%
  3Eprd_id=390847&FOLDER%3C%
  3Efolder_id=12631&bmLocale=en_US&PRDREG=POL&SOURCE=catalog
  thanks
  Frank
2003-01-13 by Ernst Dinkla
using dICE, you do not get any softening of the image at scan time.<
The consensus is that ICE should give a softening of the image. The strange
thing is that with the Nikon 8000 and NikonScan's latest version when I scan
at 4000 ppi, which will resolve grain of 160 ASA colour negative and almost
that of a 100 ASA reversal film (Agfa RSX 100, the older type), the grain
gets sharper, more pronounced. Both in a glassless 35 mm carrier and with
the wet mount glass carrier that I made.
Probably because ICE is compensating the usuall softening a bit too much. It
must be a software issue so it should be visible with the other Nikon
scanners when the latest NikonScan version is used.
Ernst
2003-01-13 by frankg_photo <fh.gross@sympatico.ca>
Thank you Simon. Working on a separate layer sounds like a good way
to go. Also, using the standalone version appears to give you much
more control than the plug-in filter. However, I always have my files
in PS's .psd format and the filter only works on .tif files - so it
means I have to save a copy as a tif , do the dust removal, then save
it as a .psd to overwrite the original - a bit of a clunky way to
work. But I may be missing someething.
Frank
<simon@s...> wrote:
> Frank
flatten the layers.
> Simon
>   ----- Original Message -----
>   From: frankg_photo <fh.gross@s...>
pointers
>   or a tutorial ?
>   thanks
>   Frank
2003-01-14 by Simon Lamb
Frank
Are you using the Mac or Windows version.  In the standalone Mac version, all it seems to allow is a menu option to detect and remove dust and scratches.  Seems like much less control than in the plug-in version.
Simon
  Sent: Monday, January 13, 2003 12:50 PM
  Subject: Re: [Digital BW] Polaroid's Dust & Scratches
  Frank
  <simon@s...> wrote:
  > Frank
  flatten the layers.
  > Simon
  pointers
  >   or a tutorial ?
2003-01-14 by frankg_photo <fh.gross@sympatico.ca>
Windoze.
Seems like they've reversed the feature list:-)
Many more options in the standalone vs plug-in
> Frank
version.
> Simon
way
much
files
it
save
>   Frank
>   <simon@s...> wrote:
>   > Frank
of
setting.  I
imperfections.
apply
I
finished I
>   flatten the layers.
time to
than
any
>   > Simon
Scratches
>   pointers
>   >   or a tutorial ?
