[Digital BW] MIS Hextone set Question
2003-01-17 by Paul Roark
Tom, >... Can anyone tell me if any of the Variable >Mix Quad inks for the 1160 can be used in place of the >1200 hextone set? ... The only differences/additions are the light/photo inks -- the light toner and light cyan (gray). NOTE, the hextone and quadtone ink positions are different. In the quadtone 1160 the single toner is in the Yellow position. In the hextone 1200 the toner is in the Magenta position (so as to take advantage of the light/photo position). The Magenta-position toner is the same as the quadtone yellow-position toner. So, all you have to do is buy some Photo/light cyan (gray) and Photo/light Magenta (the light toner). Paul http://www.PaulRoark.com
