[Digital BW] Re: metamerism
2003-01-30 by Paul Roark
>I suspect all media undergoes different degrees of metamerism. >When you view your Epson 1280 dye based ink print under >two light sources, the degree of metamerism is far less >than when you view pigmented inks from a 2000P. The 2000P Epson Archival pigments are famous for their metamerism. I'm now experimenting with an Epson Archival pigment-based VM-S inkset. My major concern was that the metamerism of those Archival pigs would wreck the concept. However, it looks like the magenta and cyan pigments do not add any noticeable metamerism to the base gray ink (which must be slightly cool). UltraChrome users appear to notice the same lack of metamerism with the UC cyan and magenta; the problem is the yellow. What really surprised me with the experimental vm-s is that the Epson Archival sepia toner, which has a significant amount of Archival light yellow, has no more metamerism than the current vm-s sepia toner, which is composed of MIS pigments. The Epson Archival and current vm-s certainly do exhibit metamerism when they are printed with a sepia tone. They are much warmer under tungsten than daylight. Luckily, there is enough magenta in the mix to offset the famous Epson Archival ink green shift. The sepia tone simply shifts from redder under tungsten to more yellow and lower gamut under daylight. Since the shift is consistent with what viewers would expect, it is not a major problem. I don't think I've ever heard someone complain of the metamerism in the current vm-s. It's there, but it just is not an inappropriate shift that draws attention to itself. Paul http://www.PaulRoark.com
