Re:Epson 2200 First results
2003-02-03 by adounoucos@aol.com
Hi all, Been lurking for several months trying to decide on a printer. Bit the bullet and bought the 2200 last Friday (CompUSA-caught a shipment by dumb luck). Most concerned about neutral B/W as I have made a book dummy now being reviewed for publication. Had a heck of a time with my Photo EX getting either the green or magenta out. After getting the 2200 up and running, out-of-the-box color looked fine on a full range test image. First step in B/W was converting the image to B/W with channel mixer then print with 7 inks @ 2880 dpi using basically default settings. Image scale was fine with a very slight magenta cast in both tungsten and daylight viewing. Second step was black-only similar to Clayton Jones work flow. The result was a bit warm as many have said, although it was OK for a sunny scene. More faint sepia than magenta. Basically very pleasing to the eye and as fine a dot pattern as I ever got on the EX in six inks. Under the Lupe however the dot pattern was coarser than test one. Third test was the photorealistic WF by Carl Schofield outlined in www.luminous-landscape.com site on 2200 printing staying at 2880 dpi. This was dead neutral in daylight, ever so slightly warm under tungsten, only visible by quick side-by-side comparisons to daylight. These are very early tests for me. Have not looked at a 21 step gray scale yet which is next, or different kinds of images. But short of custom profiling, the Schofield method is probably an excellent beginning for those of us who need to crank out B/W images while we are getting deeper into a fully color managed work flow. Many thanks to Harald, and the Real World Photoshop 7 authors for a high speed education on color management. I'm amazed at the number of combinations that can be used with different results. Trick is to keep making images too. Thanks again to all the posters who led me to this point. Angelo [Non-text portions of this message have been removed]
