Gimp-Print + Linux
Gimp-Print + Linux
2003-02-05 by André Vallejo
Let me see if I follow this: You're saying that printing quads with
Gimp-Print under Linux or an emulator can provide as much control and good
prints as with ImagePrint? And maybe neutral prints from color inksets? Is
it so? A bit confused here...
Andr\ufffd
Re: Gimp-Print + Linux
2003-02-06 by Roy Harrington <roy@harrington.com>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, André
with
control and good
inksets? Is
> André
Well I don't run Linux so I can't provide Linux binaries, I run
Mac OS X 10.2.3 and the binaries run on that.  The bit of
source code I wrote should be fairly easy to port to Linux
so a Linux solution is not at all out of the question.  In fact I
have a friend with Linux so I'll investigate.
The main goal is to provide a completely grayscale
workflow and capability to control multiple gray inks and
optional toner inks.   ImagePrint does more in terms of a
layout tool but you have to use a supported ink set.
For me the flexibility of using anybody's inks is important
and of course the fact that gimp-print is free is great.  I
don't need all the bells & whistles that IP has.  For those
using any of the MIS quadtone inks or the Piezo inks,
using PS plugins or RGB workflows, I think this method
should be easier and as good or better.   The one price
you have to pay at least so far is working your own curves.
As far as neutral prints from color inks, calibration is certainly
going to be an issue.  But I suspect metamerism problems
are likely to be a problem -- and that's an ink issue more
than software.
One last caveat is that with the new 2200 and x600
printers there are some B&W printing options that my
code cannot do at least now.  So far I don't have separate
control of the light-black ink so IP may have the edge there.
Hope that helps.
Roy
roy@harrington.com
2003-02-08 by Bruce Kinch
Hi Roy-
I am very interested in what you are doing, as I am also on a Mac and
don't need the bells, whistles, or price of Imageprint. Where are you
located?
Bruce.
Bruce C. Kinch
Associate Professor of Photography
The Art Institute of Boston at Lesley University
