Vuescan vs. Nikon software
2003-02-12 by Stephen Kobrin <skobrin@hotmail.com>
Somewhere in the midst of the torrent of posts about ever getting a
simple B&W print, someone noted that Nikon software compresses the
tonal range vis-a-vis Vuescan.  I scan with a Nikon LS-2000 using
Nikon software and would like to hear more about this topic.  (I must
say I am even more confused about optimal scanning resolution after
the last few days -- I typically scan at either 360 or 400.)  I look
at scanning as a means to get as much information from the negative
into PS as possible and if Vuescan will pull more out of the
negative, I would be willing to give it a try.  Any comments
appreciated.
Steve
Re: Vuescan vs. Nikon software
2003-02-12 by Bob_Michaels <Bob@BobMichaels.org>
Just download the free trial of Vuescan (www.hamrick.com) and try it.
Quick and easy. It's the full program but puts "$40" all over the
scan. I bet after you use the free trial, you'll pay the $40 for the
key that removes the price tag.
Bob Michaels
 --- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Stephen Kobrin
> appreciated.
> Steve
Re: [Digital BW] Vuescan vs. Nikon software
2003-02-12 by Carolyn Frayn
Hi Stephen... when you say you typically scan at 360 or 400, I'm
assuming you mean final print size. When I used my LS2000 I scanned at
2700. My printer then, the EX, was I believe 1440 x 720, following the
old epson rule of thirds that would mean 480 files, but I typically
sent 240 and 360 to get larger print sizes without resampling ... I
assumed then that the lower 720 was the truer resolution. But what did
I know. These days I throw all sorts of odd resolution sizes at my
epsons, I don't see a difference for the most part unless I go under
300, but I do notice at times that I alleviate some microbanding in
quad printing with a whacked out dpi setting.... could be wishful
thinking.
>  I look
> appreciated.
As another post suggests, I'd just give it a go, you're the best judge.
  I never used it with my LS2000, it didn't exist then to my knowledge.
Carolyn
Re: [Digital BW] Re: Vuescan vs. Nikon software
2003-02-12 by Iain Kirk
Bob,
I totally agree with your recommendations re "Vuescan"... I still a
relative novice when it comes to the differences between scanner
software but even I can see that Vuescan is the business, so long as
you take the time to work at using its full potential.
Sl\ufffdinte
Iain
To:
<Bob@...>
Date sent:      	Wed, 12 Feb 2003 01:35:30 -0000
Subject:        	[Digital BW] Re: Vuescan vs. Nikon software
Send reply to:
[ Double-click this line for list subscription options ]
Bob Michaels
Please visit the Group Homepage to check the Files, Bookmarks, Polls
and other resources as they are often being updated. The page is at:
unsubscribe, please edit your Membership preferences by visiting this
same page.
- As threads develop, trim off excess portions of earlier messages to
keep them short.
- As the topic of a thread changes remember to change the subject
header.
- Good manners are required at all time. No personal attacks or
&amp;amp;quot;flames.&amp;amp;quot;
- Before posting a question, search the message archives and the
various resources on the homepage.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
2003-02-12 by B. Alex Pettit Jr. <a_pettit_jr@yahoo.co
And,
If you have some problems with the software on a particular scanner, (
Polaroid Sprintscan45 in my case ), Ed is very quick with making
patches to his software to help !!!  A very worthwhile $40 investment
IMO....
Best,
Alex
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Iain Kirk"
<ham4472@l...> wrote:
> Bob,
> Sláinte
> Iain
> Bob Michaels
2003-02-12 by danielstaver <daniel@petraflux.com>
Absolutely! He's fixed two bugs already based on emails I've sent him,
and often supplies patches within days. Highly recommended.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "B. Alex Pettit
Jr. <a_pettit_jr@y...>" <a_pettit_jr@y...> wrote:
> And,
> IMO....
> Best,
> Alex
> > Bob,
> > Sláinte
> > Iain
> > Bob Michaels
Hi Carolyn,
I'm sorry, I should have been more specific. Yes, I usually decide on
the print size when scanning -- actually I scan a bit bigger than I
want to print to allow for cropping -- and then typically scan at 400
unless the print size is large enough to bump up again my scanner's
limits.
Steve
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Carolyn Frayn
a
must
after
at
did
under
> thinking.
> >  I look
negative
> > appreciated.
judge.
knowledge.
> Carolyn
2003-02-12 by dsmithhfx <dsmithhfx@yahoo.com>
Got a question about Vuescan -- I can't seem to open native Vuescan
48-bit TIFs (with compression) in Mac Photoshop 6 (they open but with
weird rainbowy garbage and half the image missing), but I can open
them no problem in Win PS6.
2003-02-12 by craig <craygc@yahoo.com>
Dont know if this is your problem but the PC and the Mac write the bit order of the data reversed to each other. this is called little and big endian format and can cause some problems with file transfers between the two platforms. Dont know about PS 6 but PS 7 gives a format option in the save command.
regards
Craig
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "dsmithhfx <dsmithhfx@y...>" <dsmithhfx@y...> wrote:
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "craig
That's true, but PS (Win & Mac) has no problem opening PS TIF's saved
in the 'other' format. Baffling then that PS Win can open the VS TIFs
correctly, but PS Mac apparently can't.
2003-02-12 by cschaible94111 <cschaible@cooley.com>
Steve:
I said that.  What I meant was that the Nikon software that comes
with the 4000 arbitrarily refuses to place any value within
approximately the 90-100% (or 0-25 on a 256 scale) range.  Nikon
supposedly has a rationale for this, but I don't buy it.  As far as I
can tell, the effect is to bunch up all the values that would
naturally fall in the proscribed range at around 90.  Sometimes an
image will tolerate this, and so I use the Nikon software.  Sometimes
it won't, and so I use Vuescan.  In general, the situation is less
than totally satisfactory.  However, like all this stuff, it works
well enough, and will, I'm sure, improve over time.
Chuck
must
look
> appreciated.
> Steve
Hi again Steve, if I were you I'd just scan everything at your scanners
limits, which is 2700, then resize with or without resampling in your
image editor.  2700 is not a large file for 35mm. I believe you said
something about getting all you could from your scan (with regards to
vuescan), scanning full res is one of the ways to do it in my opinion.
Carolyn
On Wednesday, February 12, 2003, at 06:29  AM, Stephen Kobrin  wrote:
> Hi Carolyn,
> limits.
> Steve
