Re: Piezo vs. IP5 RIP
2003-02-25 by Mitch Alland
Sue: > A. Getting custom profiles for various paper combinations. This alone > probably won't get me the perfection I'm looking for. Completely > neutral > please!!! My experience confirms that it's virtually impossible to get "neutral" B&W by printing RGB, even with custom profiles. Several years ago, I had a Fuji Pictrography 4000 that had a calibrator to linearize it, an ideal situation for making a custom profile that should yield neutral B&W. At that time, Bruce Fraser, co-author of Real World Photoshop, made a custom profile for me. After extensive work on it, he concluded that "ICC profiles just aren't a good solution to achieve B&W prints without a color cast." He ended up making a PS adjustment curve that worked much better, but there were still some images that would never print neutral. [You will find statements such as the review on the Luminous Landscape forum that state that the 2200 prints neutral B&W right out of the box; but don't believe it as this review seems to have been made someone who must be colorblind, or at least without the ability to judge what is a good B&W print.] > B. IP5 RIP - expensive (sort of) and mixed reviews for Mac as well as > little documentation...ie "it's difficult." That scares me. I can't > handle > endless toying with no support. Will still need the custom profiles. First, don't even try using IP5 on System 9, on which it is kludgy owing to the operating system's lack of multi-tasking. On OSX, IP5 runs fine and is easy to use, just follow the instructions carefully about how to instal the printer and enter the encryption key, making sure that you select the correct connection-type (USB vs network). Also, make sure that Classic is not running when your using IP5. I'm here in Bangkok where I cannot just pick up the phone and call ColorByte. My problems were the ones I've just mentioned, and I got prompt responses by e-mail; and, on New Year's Eve, ColorByte telephoned me here in Bangkok to solve my problem, so the support they provided was outstanding. However, if you follow my foregoing suggestions, you should have no problems. You will not need custom profiles with IP5 because their profiles are so accurate. Andrew Rodney, a well-known guru on these matters, stated on this forum that the IP5 profiles are better than he can make -- and his company makes custom profiles for clients. For color, I found the IP5 profiles even slightly better, with better shadow detail than the outstanding profiles that Bill Atkinson has made for the 9600/7600. [I use the 7600 which is similar to the 2200 in results]. So far I have printed mainly in color with IP5, but the little experience printing with IP5 so far has resulted in the following preliminary conclusions: 1. IP5 produces absolutely neutral B&W and, using Tint Picker, prints can be subtly toned for excellent results that are more attarctive than the un-toned prints. 2. I find the quality (in terms of dithering) and the gradation to equal PiezographyBW. But I should hasten to add that Robert Morrison, on this forum, finds that IP5 compresses the darkest tones somewhat more than either the monitor image or PiezoBW. I'll have to do some more B&W printing with IP5 before I have a firm conclusion on this. When I was deciding whether to buy IP5, Jon Cone wrote me a message in response to a question stating, that he found "ImagePrint as every bit as good as PiezographyBW Pro24 which is why it was going to be the engine in Piezography2." --Mitch/Bangkok
