WYSIWYP ink formula and workflow for 1280
2003-03-03 by Steven Karafyllakis <stevek@evcom.net>
Hello all;
Between buying a wide-format printer and all the excitement and
hushed (we're all sooo restrained about it) anticipation of all
these new printing solutions coming on line, I'd almost set aside my
1280 and the custom ink-set I'd been working on for it. Today while
refilling some carts (and swearing at the nuisance of it)  it slowly
sank in that there may still be a temporary need for this ink-set
among 1280 users: Paul's new VM set may not be available for this
machine for a while, and may well be based on the same curves (Paul
might give us his thoughts on this). If that's the case, if you had
a 1280 (as I do) that doesn't work well with those curves, you still
have a problem. Cone's new profiling system will be available first
for the Cannons and then for Epsons, so it may be a few weeks to a
few months for that, and PixelPixasso, well, who knows. At any rate,
I've decided to post the mix and settings; hopefully it'll provide a
workable solution for some of the 1280 owners who can't use the VM
curves, until something better comes along. Although, for my 1280,
the only real weak points are the life-span issue, and the lack of
variable tone.
There's a link on my website: http://www.stevekphoto.com
I would appreciate some feedback from anyone who tries it.
Steve k
Re: WYSIWYP ink formula and workflow for 1280 (Roark please chime in)
2003-03-03 by Shilesh Jani <shilesh.jani@smith-nephew.
Steve,
Thank you for this tip.  The key insight you had was to make the
density of cyan the same as magenta, and photocyan the same as
photomagenta.  I am surprised you made the density of yellow greater
than the photocyan and photomagenta.  I use the FS inks in a very
similar fashion to your method:
Cyan and magenta = dark ink (cyan FS ink)
Photocyan and photomagenta = medium ink (magenta FS ink)
Yellow = light ink (yellow FS ink).
This produces WYSISYP for Eclipse Satine papers. For EAM and
Hahenemuhle line, the 90 and 95% need slight lightening, while the 5
and 10% need slight darkening.
It will be interesting to see if the new Piezography system does not
use this ink arrangment.  It would be amenable to profiling based
purely on density, not on color based saparation.  The Epson driver
(and Canon, no doubt) does this very well!
Regards.
Shilesh
PS: Excellent photographs on your web-site.  Wish you would
participate in O'Connell's print exchanges so I could get some of
your prints.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Steven
Karafyllakis <stevek@e...>" <stevek@e...> wrote:
> Hello all;
my
slowly
still
rate,
a
> variable tone.
> Steve k
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Shilesh Jani
<shilesh.jani@s...>" <shilesh.jani@s...> wrote:
> Steve,
> photomagenta.
I actually have been using a different density for each ink; In the
end it just got too tedious keeping track & refilling, etc., so I
averaged out each pair, and it worked just as well... the KISS
principle in action.
The biggest problem I had with this was maintaining good contrast in
the mid-range; too much ink and the midtones posterize, too little
and the highlights suffer. Making the yellow higher density seems to
give better highlight detail without filling in the mid tones.
>>and I use the FS inks in a very
I started by doing something very similar to this with the VM inks;
It got to be too much nuisance to color-balnce those inks however,
and I was not comfortable with the stability of the toners- my own
informal fade tests indicated that they color-shifted quicker than a
pure black inkset, though the difference probably wasn't that
significant
5
not
I suspect Cone has set up his profiling system on his existing ink
arrangement, whatever that is. After all, he can't stop producing
those inks yet, so why come up with a whole new set of
densities>carts>bottles, etc.?
driver
> Regards.
> Shilesh
> your prints.
Thanks-and I will participate, as soon as I can get away from
refilling carts-it's just too much nuisance!
Steve K
> > Hello all;
aside
> my
while
> slowly
set
this
(Paul
had
> still
first
a
> rate,
provide
> a
VM
1280,
of
> > variable tone.
> > Steve k
