unblocking shadows, bo (MIS dye inks)
2003-03-03 by dsmithhfx <dsmithhfx@yahoo.com>
Hi, I'm fairly new to black + white photo inkjet printing, and I'm beginning to get 'good' (/better) results from most of my negatives using the following settings on my 1270 loaded with the MIS dye-based color inks: negatives scanned @ 3200 ppi, 16-bit grey (Vuescan) Mostly TX, some PX and HP5 (and even some ASA 1600 Kodak Recording Film) black only HWM paper 1440 dpi working space dot gain 20% printing @ dot gain 30% gamma 2.2 color adjustment ON (but no adjustments made, i.e. brightness and contrast both at "0") After scanning I make Curve adjustments to the overall picture, and to subselections based on an 8-bit duplicate for shadow, highlight and mid-tones (sometimes mixtures), as well as to specific, manually- selected picture areas. A few of the images print 'perfectly' but most have problems with deep shadow detail: I can either print them with good shadow detail up to about 95% black (leaving the picture kind of flat), or if I try to go for a deep black, the deep shadows are clogged/clipped/posterized, with very noticeable black patches in the 95 -- 100% (roughly) black range. I have tried a couple of workarounds including applying dithering to the deep blacks, but although this is better than the black patches, it still does not quite make for a smooth, natural-looking tonal range. Printing at <30% dot gain aggravates the problem. Thanks for any suggestions!
