IP5: dither, centering, striations, and bronzing
2003-03-10 by Thomas Fors
I received an answer from ColorByte today to some of the questions I've had lately on the 2200. I believe much, if not all, of this applies to the larger-format UltraChrome printers as well. I know some people despise cross-posting, so instead, I've multi-posted this to the appropriate groups. 1. Dither The coarseness of the dither is primarily defined by the density of the light black ink. Epson's light black ink has a higher density than a typical quadtone ink set which is why, as John P. put it, "we can't run a higher level screen in the highlights." They are also limited to the amount of light cyan and light magenta they can use because the eye is very sensitive to hue shifts in those areas. It's important to remember that they're doing this with color inks, and with the Epson inks no less. I know some have had great luck with 3rd party inks, but after nasty clogs on two previous machines, I am very hesitant to run anything other than Epson inks through this $700 machine. And frankly, in the 7 months that I've been using my 2200, I had one instance where I saw very slight banding on the first print after switching from photo black to matte black. A single head cleaning cycle cleared it up. Aside from that, no clogs! 2. Centering Version 5.5 of IP (in beta at the moment) will fix this problem. It will allow you to specify the actual paper size (not just printable area) and it will handle the margins to allow centering on the paper. 3. Striations The most common cause for striations and other print artifacts is a "flared nozzle." This is a nozzle that isn't completely clogged, but fires ink in two directions instead of one. The only way to confirm a nozzle is flared is to look at a nozzle check under a microscope. A head clean can fix this, so if you're seeing these artifacts, even though it may not look clogged, I'd try a head cleaning cycle or two. 4. Gloss Differential or Bronzing Version 5.5 for the 7600/9600 will have "Wide Gamut Technology." They've basically given IP more control over how it lays ink down in chromatic areas which ultimately allows them to eliminate bronzing on gloss papers and give brighter and sharper appearing images with the matte black ink. Makes me wish I had a 7600 instead of the 2200! So, it looks like Colorbyte is listening to everyone's suggestions and comments! --Tom
