1200 and Piezotone
1200 and Piezotone
2003-03-14 by jeffsstudio9
I'm having trouble with converting my 1200 to the new Piezotone inks
using a CIS.  I had few troubles with the older inks.  Can't tell if
it is ink starvation of just clogging.  I can get about six
beautiful prints and then it starts to clog or at least does not put
down enough ink.  Each effort to clean leaves a nozzle check that is
worse each time.  It will print good for a few after letting it set
overnight.  I have tried elevating the bottles and increasing local
humidity.  None of these seem to be a fix.  Any ideas?
Re: 1200 and Piezotone
2003-03-17 by yeahsoda
Jeff,
Did you try putting some Fantastik on the head sponge and let it sit
overnight yet? That always works for me.
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jeffsstudio9"
inks
if
put
is
2003-03-17 by jeffsstudio9
It,s more like ink starvation.  I can print four-up 5x7 on A3 and
get four pages before it poops out.  Still seems like an ink supply
problem rather than clogging.  Thanks for the suggestion.  Any more
ideas?
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "yeahsoda"
<zissimos1@a...> wrote:
> Jeff,
sit
> --- In
> inks
tell
> if
> put
that
> is
set
local
