[Digital BW] Need help with a new VM setup
2003-03-21 by Paul Roark
>... 1160 ... CIS system and VM inks. >... 4 images side-by-side with the different curves >applied), and ...they were ALL VERY cold. ... Print a purge pattern and be sure the inks are in the right positions -- cyan = dark gray, magenta = light gray, yellow = bluish toner. >... I've got all the images in RGB mode ... Were the images in grayscale mode during editing, then converted to sRGB just before application of the curve? I recommend grayscale editing just to be sure R=G=B at the point of the curves being applied and to have the g/s to sRGB mode conversion apply the adjustments to the ramp in the shadow tones (which the curves assume). >In the Epson driver I've chosen these settings: >Color ink >Photo Paper (for Ilford Classic Pearl) Stay with the "Matte Paper - Heavyweight" media setting even for RC papers. Unless you have the new vm inkset -- the "Ultra Tone B&W" -- the pigmented inks will not do well on RC paper. They will "dust" and rub off easily unless then are sprayed with a fixative after printing. The new inks are much better. >Photo 1440dpi Correct. >ICM No, use "Color Controls" with "Mode" set to "Automatic." I hope this takes care of the problem. If you use RC and like warmer prints, you really ought to be using the Ultra-Tone B&W inkset, not the old VM inkset. Good luck. Paul http://www.PaulRoark.com
