Epson Stylus RIP Users help...
2003-03-31 by jsinger986
I would appreciate if Epson RIP users would tell me what settings are
being used with the Epson RIP.  In particular the "Printer Features"
section.
For RGB Souce and CMYK Source, what do you use?
When printing a greyscale image do you keep it in greyscale mode or
do you convert to RGB?  If you keep it greyscale, does it matter how
RGB Source and CMYK Source are set?  I'm also not clear on why there
is RGB source and CMYK source... isn't the file one or the other?
How about if your printing a non greyscale image like a B&W image
that has been toned and converted to RGB?
Jeff
http://www.jeffsingerphotography.com
Re: Epson Stylus RIP Users help...
I did not mean the Epson Stylus RIP... what I mean to ask was for PowerRIP X for the Epson 2200.
Jeff
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "jsinger986" <jhsinger@t...> wrote:
> section.
> Thanks,
> Jeff
2003-04-01 by danielstaver
I'm not sure if PowerRIP X behaves the same way as PowerRIP 2000 for
windows, but here's the settings I use:
It doesn't matter whether your image is grayscale or RGB. PowerRIP
doesn't require any special settings for BW. An advantage of RGB is
that you can easily change the tone of the image with curves or
combine color and black and white in the same picture.
When printing use 'Postscript color management' as output profile.
This will give you the most neutral prints. If you're interested you
can also try one of the grayscale profiles, like  'Gray gamma 2.2'.
This will make a print using the black and light black only which will
look very brown.
Select 2880dpi and your paper type in the driver setup.
That's it.
> Jeff
> > section.
> > Thanks,
> > Jeff
