Not strictly an 8 versus 16 question, but sort of
2003-04-29 by Garry Sarre
1/ is upsizing in PS Bicubic 16bit superior to upsizing in 8bit.
2/ Apart from levels and curves tonal adjustments, what else
degrades image quality in 8bit more than 16bit.
3/ When Printing B&W from an RGB image does changing from 16bit RGB
to 16bit greyscale (editing on smaller file size)and then back to
RGB for printing degrade the image more than simply staying in RGB
all the way?
Any help appreciated
Garry Sarre
www.sarre.com.au
Re: Not strictly an 8 versus 16 question, but sort of
2003-04-29 by Steven Karafyllakis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Garry Sarre"
Theoreticaly yes, and this may be one of the few situations where
you will probably see the results. What is even better, however, is
to get your hands on an app that uses a more sophisticated
interpolation algorithm like Spline-32 /64/128. Lanzcos, or Vector.
If you're on Win platform, probably the least expensive is either
the combo of Panotools (free) and PT Gui ($40.00) or Qimage, (40.00)
in 'save to file' mode if you don't want to print it right away.
Qimage is also excellent at downsizing on the fly, and feeding the
Epson driver only what it needs so no downsampling gets done by the
driver. Genuine Fractals got a lot of attention for a while, but IMO
it is way over-rated, slow, and forces you to keep it around to open
and upsample those proprietary .stng files it makes.
I've read that sharpening is best done in 16-bit, at least in theory-
 can you see the difference? unlikely, but it can't hurt.
RGB
> all the way?
I don't think so, though I'd be curious in other's opinions myself.
If you're not adding color info, you're simply triplicating the BW
info when you convert back to RGB, I see no reason any degradation
should occur. I have noticed that with cheap low-bit flat-bed
scanners you get a smoother image scanning in RGB and converting to
BW in PS, but that's not quite the same.
Steve K
> Garry Sarre
> www.sarre.com.au
