Re: [Digital BW] enlarging meter advice?
2003-05-18 by Kip Babington
I used a Gossen Labosix enlarging meter for 20+ years with moderate
success.  But they are long obsolete, depend for adjustment on a rheostat
(I think) which wears out over time and cannot be replaced, and are not
that sensitive.  A little over a year ago I bought a new enlarging meter
which is absolutely fabulous in its functionality and accuracy.  It is the
Zone Master II, comes from RH Designs in England, and meets all of your
criteria except for price.  But it is the first enlarging meter that I've
used on which I can routinely get a great print on the first exposure.
RH Designs has a web site at
http://www.rhdesigns.co.uk/zonemaster.html.  (This is the link to the
individual unit - you can look around at other products from there as
well.)  This site has some fairly extensive discussion about how these
meters work, as well as instruction manuals that you can download and
peruse.  As I say, this is not a cheap unit, but if you figure in the cost
of paper saved you might find that overall it is more economical than other
things you might try.  In addition, it allows you to produce more (or save
time, depending on your perspective) so there's a payback in time as well.
Hope this helps.
Kip
At 5/18/2003 05:54 PM +0000, Scott wrote:
>can anyone recommend an enlarging meter?  B&W or course.  Needs to be
>useable (readable) in fairly dim safelight, ideally with an illuminated
>readout,
>not phosphorescent, and moderately economical would be nice
