Re: [Digital BW] 4 vs 6 inkjet for BW
2003-05-19 by Martin Wesley
From: "heechee92" <heechee@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, May 19, 2003 10:33 AM Subject: [Digital BW] 4 vs 6 inkjet for BW > Hello all, > > I have a general question. I'm new to digital BW. I'm getting a > Canoscan 4000 in a few > days and I'm just doing this for a hobby. My question is that I have > an Epson Photo > 750 and a Espon 760. I'm leaning towards using the 750 for all of my > color printing > and dedicating the 760 for my BW work. Would using the 750 as the > dedicated BW > printer using the replacement ink produce that much better prints > becuase of the 6 > ink resevore? I have been doing some research and haven't seen much > on the > difference between 4 ink BW vs 6 ink BW. Does anyone know which would > be better? > Six shades of gray ink does not offer an advantage over four. The Piezotone system for instance uses only 4 inks (1 black and 3 grays) in the six channel printers doubling up the two darker grays. What can help you by using a 6-color printer is the total number of nozzles available for printing. Practically the difference is probably negligible though. Your biggest problem is that there are no software/workflows for either the 750 or the 760. Unless you are prepared to do a lot of work developing curves to work with these printers, I would recommend that you use a different model for dedicated B&W. Martin Wesley http://www.borderless-photos.de/guests.html
