RE: B&W Film
RE: B&W Film
2003-05-20 by pwdloge
The intent of this letter is twofold, first to present my viewpoint
and the other to stimulate a response, either pro or con.
Concerning B&W film
Scene range can be 1:50,000 or more
B&W film range is about 1:120
No. 2 paper about a 1:50 range
Any B&W print is an abstraction of  the original scene.
How you select to present that abstraction is a matter of choice.
The limiting factor is the paper range.
The ideal negative would fit the range of the paper and present the
elements in the scene that are important to you.
The ideal negative could be one that prints on a No.2 paper or any
other grade that matches the type of negative that contains the
densities you need to make the print you visualize.
Every paper contrast grade has the same white and black, it is the
number of steps in between that are determined by paper grade.
Not every photograph requires a No.2 negative or paper to obtain a
desired effect.
The important thing is to have the correct negative range for the
paper contrast used to carry out the intent of the photograph.
The method for controlling negative density range for many
photographers is the Zone System.  It also is the tool for making
visualization of the finished photo possible before the shutter is
tripped.
Question:
 A negative is made on Kodalith film.  There is only one density,
maximum density.  Therefore the print will only be black and white.
What paper will be the best to use for printing?
Answer:
Any grade
All grades have black and white, the negative does not contain any
other densities so the negative range fits all of the paper ranges
with correct paper exposure and development.
RE: B&W Film
2003-05-20 by HPA
I wonder if the author of the post about Kodalith (who did not sign their
name to it) has ever used the film.  Try shooting the film at ASA 12 (in
flat light) or ASA 6 (in contrasty light).  Develop in DK50, D76, or HC110B
for four to twelve minutes by inspection.  I think you will be astonished at
the superlative tonal range of this film.  I have done it, and I know other
photographers who have soft and luminous landscape prints in the Museum of
Modern Art, made with precisely this technique.
Tom Robinson
> Question:
> Answer:
> Any grade
