Re: [Digital BW] Re: Color to BW, was Digital, film, scanning comparisons
2003-05-22 by Anthony Atkielski
Peter writes:
> Let's not get all mystical about it.
It is not mysticism, it is hard science, as I have explained ... several
times.
> A response curve is a vector
> of scalars.
Well, that vector has only three scalars in it after you take the picture:
red, green, and blue.  Try to reconstruct an arbitrary curve from that.
> It should be simple linear algebra to take two
> response curves and come up with a third curve
> that represents the conversion of one to the other.
Sure.  The problem is that you have nothing to which you can apply that
third curve.  You have only three values: red, blue, and green.  You need a
whole curve to which you can apply your conversion--but it's gone.
> The only case that would fail is if the
> target response curve had a wider latitude than
> the source one.
_Most_ cases will fail.  Unless the entire curve is a function of the three
RGB values, it will fail.
2003-05-22 by Peter Nelson
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Anthony
Atkielski" <anthony@a...> wrote:
> Peter writes:
several
> times.
> > of scalars.
picture:
No it doesn't - it has however many scalars you need for your bit
resolution.    For a 12 bit scan it has 4096 scalars in it, and
remember, you have three vectors - one each for the R,G, and B
response curves.
Peter writes:
> need for your bit resolution.    For a 12 bit scan
> it has 4096 scalars in it, and remember, you have
> response curves.
Feel free to answer my question about the yellow-sensitive film, if you
believe I am wrong.
