Re: [Digital BW] Pros and Cons of the different systems
2003-05-23 by Martin Wesley
Sent: Wednesday, May 21, 2003 5:00 PM
Subject: [Digital BW] Pros and Cons of the different systems
> I've been following this group for a while and I seen many people saying
> "the system I use is the best" (no offense intended).
> My question, is I'm reserecting my 1200 from a fatal clog ($10 kit from
> fixyourownprinter.com) and I'm trying to decide which system to go with.
> currently I'm printing with Gen4 inks/cone profiles/1280 system.  But I
> really want to get some good black and whites.
> Does any one know where I can look at the pro's/con's of the various
systems
> out there.  My initial thoughts are going with piezoBW from cone, but I've
> heard there are considerable problems with clogging.  But they have the
best
> system with profiles.  So any suggestions / comparisons.
> Thanks in advance
Tom,
I started out with a 1200 as well. I and others found it to be one of the
most problem prone of all the Espon printers for use with carbon pigment
inks. When I switched to a 1280 things were much better. The clogging issues
with Piezo ink were with the original inks. The new Piezotones do not suffer
from these problems. I have used both and the new inks have worked very well
for me.
Martin Wesley
http://www.borderless-photos.de/guests.html
