Piezography/Sundance Confusion
2003-05-25 by normsams
Are the Sundance inks the same as the Piezo inks? If not are they compatible with the Piezography software? Is the Image Export BW sold by BWGuys the same as the Piezography software? Thanks in advance. Norm
2003-05-25 by Austin Franklin
> Are the Sundance inks the same as the Piezo inks? If not are they > compatible with the Piezography software? Is the Image Export BW sold by > BWGuys the same as the Piezography software? > > Thanks in advance. > > Norm Hi Norm, My understanding, despite what was "marketed" at the time, is that the Sundance inks were OEM'd (bought from Sundance) by Cone and re-named Piezo, so yes, they would be the same inks if that is true. Also, it is my understanding that Cone did not develop the Piezo driver, that again, was OEM'd from an outside party. Cone apparently had a two year exclusive agreement which recently was up, and apparently not renewed. This is why the "original" inks and software are no longer available from Cone...and why Cone had to develop a new "system". Whether this new system is actually better or not, I question. I tried to ask some particular questions about it (like does it do the purported dithering between tones to provide "thousands of tones" that was claimed of the original Piezo, and does it print at 3x720 or 2160DPI as was claimed of the original Piezo), and got no worthwhile answers. I know some may say "just try it", but I have no intention of spending a thousand dollars AGAIN just to muddle through problems that I already have solved and working nicely with my current system. Austin
2003-05-25 by Kevin Gulstene
Norm- > Are the Sundance inks the same as the Piezo inks? If not are they > compatible with the Piezography software? Is the Image Export BW sold > by > BWGuys the same as the Piezography software? > > Thanks in advance. > > Norm My understanding is that the original Piezography inks were the same as the Sundance inks (and in fact made by Sundance). The new Piezotone inks are definitely not the same as the Sundance inks. The Image Export from BWGuys is the same as the Piezography software. -- Kevin Gulstene www.dockwalker.com
2003-05-25 by sdmey4@aol.com
In a message dated 5/25/2003 8:48:17 AM Pacific Daylight Time, normsams@... writes: > Are the Sundance inks the same as the Piezo inks? If not are they > compatible with the Piezography software? Is the Image Export BW sold by > BWGuys the same as the Piezography software? > > Thanks in advance. > > Norm > Sundance inks are not the same as the new "piezotone" inks now sold by inkjetmall. The new Piezotones come in 4 differently hued sets and are much more stable! They don't shift to warm over time. I have found the Piezotones inks to be quite compatible with the original Piezo driver as well as the Piezo Pro RIP both of which where made by R9 corp. Now sold through BWGuys. My legacy files that where created for the original sundance inks have transported to the new inks with minimal fuss. I use Piezotone Sepia in a 3000 and even a custom blend based on the warm neutral piezotone set in a 7000. All is good with the new inks and old driver. Too be clear! Sundance inks are the original inks and the new product and completely different formula is now referred to as "Piezotones" Steven Meyers [Non-text portions of this message have been removed]
2003-05-25 by Tom OConnell
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "normsams" <normsams@w...> wrote: > Are the Sundance inks the same as the Piezo inks? If not are they > compatible with the Piezography software? Is the Image Export BW sold by > BWGuys the same as the Piezography software? > > Thanks in advance. > > Norm Norm- You've gotten good answers on the inks...the interesting part is that the software is all the same...and you might gain some advantage by loading the profiles from a different vendor than you started with... I started with Piezo and have recently loaded the sundance profiles...for some reason they then don't see any of the piezo ones, but that's ok...there are more that I use in the sundance set. All of the software works quite well with the MIS FS and FSN inks which have caused me ZERO problems (and Piezo original inks were a nightmare for me...and many other desktop printers...to be fair, it seems that the wide format users really had no problems with the original inks and apparently a lot of them still use them). The Piezotones are a completely new animal and most folks seem to have little problem with them...if they work for you, they are beautiful. cheers, tom
2003-05-26 by Martin Wesley
From: "normsams" <normsams@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Sunday, May 25, 2003 8:46 AM Subject: [Digital BW] Piezography/Sundance Confusion > Are the Sundance inks the same as the Piezo inks? If not are they > compatible with the Piezography software? Is the Image Export BW sold by > BWGuys the same as the Piezography software? > > Thanks in advance. > Norm, Well I don't know if all our answers have helped or added to your understandable confusion. Here is the timeline as I understand it. (Someone please jump in if I have any of this wrong.) Sundance, an ink company, and R9, a software company, teamed up and started marketing Sundance inks and the R9 plugin driver to go with them. They sold the inks through Digital Art Supplies. They then entered into an exclusive marketing arrangement for 2(?) years with ConeTech (Inkjetmall) who rebranded the inks and the plug-in as Piezography. Only one hue or color of quad inks was available and it suffered from various problems, primarily excessive clogging, the ink warm shifted with time and some people felt the ink had a bit of a green cast to it. The software worked very well and is still regarded highly. Initially the software cost was high. (In the mean time MIS released a set of inks called "Full Spectrum" which closely matched the hue and density of the original Piezo inks so that they could be used with the Piezo/R9 plug-in. They also offered lower cost and greatly improved clogging, warm shift and fade. I will leave the MIS Variable Mix inks out of this discussion.) At the end of the exclusive marketing contract Inkjetmall and Sundance/R9 separated their ink business. Inkjetmall brought out a new line of inks called PiezoTone that comes in 4 hues, Warm, Cool, Selenium and Carbon-Sepia. These are designed to be used with the Piezo/R9 plug-in. Inkjetmall has announced the immanent release of new software that will entirely end their business connection to R9. Significantly their new software promises to expand the usable printers for grayscale inks to brands of printers other than Epson. When the split occurred Sundance/R9 started doing business under the name BWGuys.com. They continue to sell the original Sundance/Piezo ink under the name "Sundance BW Neutral Warm Ink" and introduced a new ink "Sundance BW Neutral Cool" which has a different chemistry and does not suffer from the problems noted with the original ink. My understanding is that they have continued to develop the plug-in which they call "Image Export BW" and that it has additional paper profiles not in the Piezo plug-in. Sundance/R9 have also recently released new inks "Septones" based on their new ink chemistry and new software "Pixel Pixasso) designed to work in the new Epson 7-color printers. The system uses a black, 3 warm gray inks and 3 cool gray inks with the software to provide a variable hue printing solution with the ease of use of the plugin. If you are still confused I don't blame you! Martin Wesley
