Need help with OPM
Need help with OPM
2003-05-31 by Diana Park
Antonis or anyone,
Has anyone had a sudden problem printing solid black areas with OPM
1.02 on a Mac? Yesterday I did a print with large solid black areas
and it printed fine. The next print had weird white gaps running in
the printhead direction (almost like the heads were dragging against
the paper). Did a nozzle check - fine. Cleaned the print heads, just
in case - fine. Printed the file from Photoshop - fine. But print the
file from OPM and the gaps/streaks appear. But only in the 100% black
area. I haven't changed the black cartridge recently - maybe I should
try that. I also tried reinstalling the software, and I've tried
different profiles, but still the streaks. Any ideas??
Diana
(who's TRYING to make some Jerry Olson memorial prints, but not succeeding...)
Re: Need help with OPM
2003-06-01 by Antonis Ricos
Diana,
haven't seen that one in my tests. Sometimes a simple nozzle check is not
enough to show what happens.
Try to print a grayscale with a black only profile and compare to a black-only
print from Photoshop.
Use the Epson Utility to see how much ink there is in the cart (is it on its last
legs?)
The latest OPM beta is 1.02b dated 4/9/03  5:52pm. If you don't have it, please
ask Bowhaus to let you try it as a possible fix.
Sorry to hear of these wows - I know it's frustrating when you are trying to
actually make prints and not just testing!
Antonis
<please also mention the profiles you are using>
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Diana Park
<dip@m...> wrote:
> Antonis or anyone,
> Diana
succeeding...)
2003-06-01 by nick90290
<dip@m...> wrote:
> Antonis or anyone,
against
just
the file from OPM and the gaps/streaks appear. But only in the 100%
black area. I haven't changed the black cartridge recently - maybe I
should try that. I also tried reinstalling the software, and I've
tried different profiles, but still the streaks. Any ideas??
> Diana
Hi Diana
Yes, I've had the same problem. Drove me crazy for a while, doing all
the same things you did, none of which made any difference either. My
problem was more a very fine banding in the black areas that under
the loupe looked like tiny white diagonal tooth(?) lines.
Two things I suggest - like Antonis says, get the most recent OPM,
since Bowhaus have been addressing this problem with updates. It's
only problem there is in - for me - an otherwise fabulous software
system that enables me to get prints exactly the way I want them.
Secondly, if your cartridge is low, try changing it. Antonis
suggested this to me, and it did seem to make a difference. A nozzle
check will not reveal the problem - they'll always come up fine.
If you're able to fix the problem, please write and say how you fixed
it, since I'm always worried that this problem might suddenly come
back.
Nick
2003-06-01 by Phil Rose
Yes, Diana, I have seen the exact same problem in 100% black
areas when printing with OPM (v 1.02). I think it's turning out to be
a fairly common defect--you're the 4th or 5th (including myself)
that I know about--among the relatively few people who have
reported _any_ feedback about OPM in forums and newsgroups.
Antonis and Carl (and some others I guess) state that they do
not see this problem, so it's a little confusing as to why there is
such a disparity in the results. The version I have of OPM is
whatever was available from the Bowhaus website as of one
week ago. If there's anything more recent I don't know how to get
it.
Aside from that "show-stopper" of a problem, the results I got
were quite nice. I used Carl Schofield's linearized versions of
Antonis's profiles. I can reproduce the defect in the 100% black
test patch of Antonis's 26-step grayscale, but it is not apparent in
any of the lower densities.
My temporary "workaround" for dealing with the 100% black
issue is to simply reduce 100% black pixels to 99%. This is
easily done in Photoshop by making a one-level change in the
"output levels". Of course that also adds one level to all the tone
values below 128, but the effect may not be very noticeable. And
then all the 99% black areas print OK.  Probably there is a better
way to do this with PS curves. I hope Bowhaus comes
up with a fix because their approach to B&W printing seems so
promising.
Phil
Park <dip@m...> wrote:
> Antonis or anyone,
with OPM
areas
in
against
just
100% black
should
> Diana
not succeeding...)
Re: Need help with OPM - Phil
Phil,
(and others with the same problem), by all means please contact bowhaus
and ask for OPM 1.02b dated 4/9/03, 5:52pm. It has fixes specific for the 2200.
software@...
If you have problems reaching them, please let me know.
Antonis
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Phil Rose"
> it.
> promising.
> Phil
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, "Antonis
Ricos" <antonisphoto@y...> wrote:
> Phil,
contact bowhaus
> software@b...
A few days ago I was in email contact with Charles James at
Bowhaus concerning the problem (I mentioned that I used
v1.02), but he said nothing about a 1.02b version--perhaps he
didn't realize I was not using that one.  I'll send him a note
requesting the latest.
Phil
2003-06-01 by Diana Park
Antonis, Nick, and Phil,
Thanks for all the quick responses! Phil - your suggestion worked for
me! I went back into Photoshop and used Levels to bring the 100%
black down to 99% and no more weird streaking! I also checked my
black cartridge and it's only about half empty. My version of OPM is
1.02 so I've written to Bowhaus asking for the 1.02b version. I still
think it's strange that the first print was fine, even with 100%
areas. Besides the horizontal fine streaks, I've noticed a vertical
banding as well alternating between black amd grey when I print a
100% black box (it almost looks like the paper is buckling). These
vertical stripes ALMOST line up with the printer rollers but not
quite - they aren't perfectly uniform. Very weird!
Could this possibly be a USB problem? OPM is now sometimes having
communication errors with my printer, and it will only do 2 prints
before quitting with a Type 2 error. I haven't changed cables lately
or installed any new software, firmware, etc. I remember someone on
this list recently complaining that OPM only supported USB printer
connections, and not Firewire, so maybe the code relies on USB
protocols more heavily than say Photoshop, which had no trouble with
the 100% black (I'm grasping at straws here). It's not a full moon,
so I'm at a loss!
At any rate, many thanks to you all and I'll keep you posted on any
new discoveries I make.
Happy printing,
Diana
P.S. I've been using Carl Schofield's profiles when I want a cooler
look, and Antonis' for a warmer tone, and I love the Blender option!
--- In DigitalBlackandWhiteThePrint@yahoogroups.com, Diana Park wrote:
<I still think it's strange that the first print was fine, even with
100% areas.>>
Yes, it is strange, but again the same thing has happened to
me...twice. First time, I got over 100 prints out before it started
suddenly happening out of nowhere on my 1280 with MIS inks. Second
time, it happened after probably 200 prints on my 2200 using the
Ultrachromes. It almost seems like the heads become less tolerant of
any tiny clogs that might build up during the course of much
printing??
I must try Phil's 99% idea if and when it happens to me again. Very
interesting.
<Besides the horizontal fine streaks, I've noticed a vertical banding
as well alternating between black amd grey when I print a 100% black
box (it almost looks like the paper is buckling). These vertical
 quite - they aren't perfectly uniform. Very weird!>>
I've had exactly this as well, but a couple of cleaning cycles has
always gotten rid of this one for me. (As Antonis told me, however,
we shouldn't trust the nozzle check looking clean.)
Nick
