Re: [Digital BW] Re: Coating with a printer?
2003-06-02 by Ernst Dinkla
From: "Antonis Ricos" <antonisphoto@...> To: <DigitalBlackandWhiteThePrint@yahoogroups.com> Sent: Monday, June 02, 2003 8:04 PM Subject: [Digital BW] Re: Coating with a printer? > Steve, > > the idea has been discussed before, but probably a long enough time ago to > merit considering again. The problems are: > - how thin you have to make the coating to pass through the heads? > - given the necessary viscosity, how much of it do the heads put down to > actually coat without having to slow them down? > - if the paper comes out very wet, will it get any marks from the printer > mechanism? > - how long does it take per print, compared to the speed (but messy setup) of > a rod? > - what happens to the printer when the liquid dries in the head? will it be > re-dissolved by more of the same or will it require that a solvent be run > through - that won't harm the heads? And how will you see nozzle checks with > a clear liquid?... > > > Nevertheless, it would be nice if it worked - better yet, if one could dedicate a > single jet to coating and do it "in line" like offset printers do. Dream on.... (but, > hey, if someone invents it I'll buy it!). > > Antonis There were always dreamers so: There was a Canon inkjet that had a fluid in one of the heads to make the paper more inkjet compatible or something like that. There was a HP inkjet with a heated wire just after the print area to dry the ink fast. There's the First foil that is heat treated with infrared after printing to enclose the pigment ink in a resin. Ernst
